post #1 of 5 (permalink) Old 04-12-2011, 04:08 AM Thread Starter
I think i damaged my fork seal during transport on a trailer. It is only leaking from one fork seal tho. I was wondering if i should fork out the cash having a mechanic do it, or is it something i can tackle in my garage? Any info will help.
kager2002 is offline
post #2 of 5 (permalink) Old 04-12-2011, 04:50 AM
Deceased 1/2017
RobTheHillbilly's Avatar
Model: GL1200 Se-i Trike
Send a message via Skype™ to RobTheHillbilly
kager, Welcome to the BEST Goldwing forum in the world (IMHO).
As to your leaking fork seal, it is not a hard project to do in your garage here is a tutorial on how to do it and it is very easy to do. Just go with the pictures and it takes you step by step, and in no time you'll have it done. I used it when I did mine.
http://www.goldwingfacts.com/forums/forum9/72576.html
1986 GL1200 SE-i Trike
Thanks to my wife who puts up with me saying "I wonder if this will work" and who likes my cooking!
The Wife...Louann
Tennessee F.& A.M.
Past Master Arcana Lodge #489
32* KCCH Scottish Rite, Valley Of Knoxville Orient of Tennessee
Freemasonry--2B1ASK1
What we have done for ourselves alone dies with us, what we have done for others and the world remains and is immortal.
Albert Pike
Honorary Rhino NASSIR7
RobTheHillbilly is offline
post #3 of 5 (permalink) Old 04-12-2011, 05:02 AM
AJ1500's Avatar
If you have some mechanical ability then it's not too bad to replace the seals. there is a how to step by step on it here somewhere. you might want to coonsider converting to progressive springs while your there, I did mine not too long ago and I love the ride of the progressive springs
a couple tips
the factory springs, there are 2 per tube and they are strong and will jump out of fork when cap is removed, BE CAREFULL
if your going to put the original springs back in, do your research on how to get them back in, I can tell you I couldn't have put mine back without some special tools
the allen screws at the bottom would not come out on my forks, they just turned, so I drained it good and finished the job without removing them for inspection, I took a chance I know but it seems it was OK
I found a floor jack and a 2X6 under the frame just behind the timing cover worked great to lift the bike for the repairs, very stable
97 1500 SE
Dark Side # 1522
USCA # 8913
GOODYEAR FUEL MAX 175 60R16
Bridgestone Battlax 130/70 18
Just getting started
AJ1500 is offline
post #4 of 5 (permalink) Old 04-12-2011, 12:00 PM Thread Starter
Thanks AJ for the 2by6 tip. i was wondering how to get this heavy thing up safe!
post #5 of 5 (permalink) Old 04-12-2011, 02:46 PM
AJ1500's Avatar
Sure thing, also here is one of the tutorals to refer to
I still haven't found the one about the progressive spring install that I used when I did mine, it starts at removing the forks and then goes step by step
97 1500 SE
Dark Side # 1522
USCA # 8913
AJ1500 is offline
Fork Seal Replacement griz440 General Motorcycle Discussion Forum 0 04-08-2011 02:10 PM
Fork Seal Replacement WingMan71 Goldwing Technical Forum 5 02-17-2009 12:15 PM
fork seal replacement deblak Goldwing Technical Forum 2 05-21-2007 11:03 AM
Fork Seal Replacement Snorebaby Goldwing Technical Forum 18 02-04-2007 05:26 PM
GL1200 fork seal replacement JOHNO Goldwing Technical Forum 9 09-02-2005 03:59 PM
