post #1 of 3 (permalink) Old 05-08-2011, 05:28 PM Thread Starter
Peterbylt's Avatar
on my 85 12000 Aspencade I am in the process of replacing the fork seals and steering stem bearings.
When I pulled the springs out I noticed that the right side springs had a washer between the smaller upper and larger lower springs and the left side did not have the washer between the springs.
I thought to put the springs back together without the washer in either side then I went looking in the parts bin and found a couple of washers with the exact same outside diameter but the inside hole was much smaller.
I am thinking of replacing the original washer and putting the new washers on both sides. I do not think the the smaller hole in the center should affect the function of the shock the fluid level is below the washer.
Does anyone think the smaller hole will affect the operation of the fork?
In the picture, the original washer is on theright and the proposed replacement washer is on the left.
Peter
75 GL1000
81 GL1100
85 GL1200A
75 550F
Peterbylt is offline
post #2 of 3 (permalink) Old 05-08-2011, 07:00 PM
Looking at the fiche I can't tell which piece is which.
http://www.westernhonda.com/fiche_section_detail.asp?section=146258&catego ry=MOTORCYCLES&make=HONDA&year=1985&fv eh=3443
Just put Progressive springs in there. You'll be much happier.
post #3 of 3 (permalink) Old 05-08-2011, 07:31 PM
OnaWingAndaPrayer's Avatar
Year: 75,83I,86SEi,93A,94SE
Model: 94SE 206000 miles
I would say its #6 : plate ,spring joint
that aside i see no reason not to use the wahsers you have . I see no reason the smaller hole will affect anything either .
NASSIR 1
NASSIR 6
NASSIR 7
NASSIR 8
NASR 10 planned
Fork Seal Replacement griz440 General Motorcycle Discussion Forum 0 04-08-2011 02:10 PM
1200 LTD HELP!! Fork seal replacement gone bad Psalmist Goldwing Technical Forum 14 03-24-2011 12:30 AM
fork seal replacement knowbuddy Goldwing Technical Forum 7 01-01-2010 03:06 PM
fork seal replacement deblak Goldwing Technical Forum 2 05-21-2007 11:03 AM
Fork Seal Replacement Snorebaby Goldwing Technical Forum 18 02-04-2007 05:26 PM
