post #1 of 8 (permalink) Old 05-17-2011, 07:03 PM Thread Starter
Could somebody place the assembly inst. sheet for the driver back rest?
I just have one but some parts are missing.
Thanks
Javis
javis is offline
post #2 of 8 (permalink) Old 05-17-2011, 08:11 PM
Biker John's Avatar
Model: GL 1800
What kind of back rest is it?
2006 GL1800
Dark Red
DarkSider
Michelin Alpin PA3 195/55/16 RF
Biker John is offline
post #3 of 8 (permalink) Old 05-17-2011, 08:12 PM
Biker John's Avatar
Model: GL 1800
2006 GL1800
Dark Red
DarkSider
post #4 of 8 (permalink) Old 05-17-2011, 09:08 PM Thread Starter
Something like this:
Goldwing 1500A
http://cgi.ebay.com/ebaymotors/SHOW-...item5885d43713
Thanks
Javis
javis is offline
post #5 of 8 (permalink) Old 05-18-2011, 08:09 AM Thread Starter
Bump!!!!!!!!!!!
Javis
javis is offline
post #6 of 8 (permalink) Old 05-18-2011, 08:36 AM
Snorebaby's Avatar
What parts are missing? Can you put a couple of pics on here so we can get a better idea of what you need. They are pretty simple to put on, kinda easy.
'15 GL1800 Scarlett
'90 GL 1500 SE Pearl
'86 CMX450 Rebel
'85 GL1200 LTD---SOLD
Patriot Guard Riders #137660
Snorebaby is offline
post #7 of 8 (permalink) Old 05-18-2011, 08:51 AM
Anti-Guru
satan's Avatar
Model: '06 GL1800
There are two side rails that mount "through" the 1500's passenger grab handles. You'll see that the mounting point has one "spacer" welded to the side rail mounting plate, and one without the spacer.
Typically, "Missing parts" for mounting are:
* The second pair of spacers (one each side) -- that should be the exact same length and size as the one welded to the mounting.
* qty=4 bolts - these replace the OEM seat mounting bolts (8mm and are long enough to get all the way through the spacers (above) and mounting plate (you can measure the OEM bolt length and add the spacer length and plate thickness to find exact length needed)
* qty=4 washers for under the bolt heads...
Siderail hardware'll look like this installed (thanks AZgl1500):
Once the bike-side rails are loosely attached to the bike, you should be able to thread an adjuster nut and its washer onto each leg of the backrest's frame and stuff things together so that you can snug-up the bike/seat mounting bolts.
* Adjuster nut first - threads point toward the open end
* Then Washer
Kinda like that or ...
The Show Chrome backrest Installtion guide <- click!
satan is offline
post #8 of 8 (permalink) Old 05-18-2011, 11:23 AM Thread Starter
* Then Washer
Satan:
Thanks for the info, the spacers and the bolts are missing, with your info i will fabricate the spacers and buy the bolts.
Also, i'm doing the rear bracket ( looks like aluminum ) of the pad, because the original is broken ( 1 part is missing ).
The pictures help a lot.
again Thanks
Javis
javis is offline
Does anyone have instructions for 1500 Markland backrest da_bull Goldwing Technical Forum 6 05-21-2010 10:06 PM
Looking for a used driver backrest rgw5944 For Sale/Wanted Forum 2 05-23-2009 09:35 AM
Does this Cub Driver need flying instructions?? AZgl1800 Miscellaneous Forum 4 09-20-2008 05:49 PM
Markland Backrest Mounting Instructions for a GL1000 schmidtap Goldwing Technical Forum 8 09-13-2008 06:46 PM
Driver backrest john424 General Motorcycle Discussion Forum 8 03-20-2007 04:00 PM
