post #1 of 14 (permalink) Old 06-09-2011, 02:47 PM Thread Starter
my crankshaft seal is leaking. Does anyone have the step by step on how to replace? Also what is the part number, and where can I buy one. I have a 1984 GL1200 Aspencade.
SailorDude is offline
post #2 of 14 (permalink) Old 06-09-2011, 04:03 PM
unionjk's Avatar
http://www.bikebandit.com/houseofmot...m2341#sch16236
Part #13 for $11.35.
'RIDE TO BE SEEN'
Most common quote from a cager after killing a motorcyclist is?
"I never saw him".
unionjk is offline
post #3 of 14 (permalink) Old 06-09-2011, 04:37 PM
Other side of the pond
englishted's Avatar
The crankshaft pulley has to come off for that, and the timing belts. Procedure for timing belts on the 4 cylinder Wings is here: http://www.goldwingfacts.com/forums/...422&forum_id=9
Ted Kelly.
englishted is offline
post #4 of 14 (permalink) Old 06-09-2011, 04:53 PM
unionjk wrote: Nice thought but if you look closer they don't have it and can't get it.
The seal size is (35X59X8)mm. I've searched online and can find 35X58X8 and 35X60X8 seals but not 35X59X8.
Ken Bergen is online now
post #5 of 14 (permalink) Old 06-09-2011, 05:53 PM
Welcome ., You dont list your miles so will assume age is the factor here.
If you cant find a replacement seal you can try the fix in a can thing. There are additives available to add to your oil to swell out old seals if they are not worn out.
Go to your local auto parts store and describe your problem , they will point you to the appropriate can .
The Crazy 88
machinehead is offline
post #6 of 14 (permalink) Old 06-09-2011, 05:58 PM
The Crazy 88
post #7 of 14 (permalink) Old 06-09-2011, 06:11 PM
Senior Guru
GWNorman's Avatar
Model: GL1800, GL1500, GL1200
We had this seal discussion 3 or 4 years ago and as I recall, the GL1500 crankshaft seal is 35 X 59 X 8 just like the 1200 seal. The part number is 91201-MN5-003.
GWNorman is offline
post #8 of 14 (permalink) Old 06-09-2011, 06:20 PM
Senior Guru
GWNorman's Avatar
I meant to add that the same seal fits the Valkyrie. You can get it here:
http://www.cheapcycleparts.com/produ...l-seal-35x59x8
GWNorman is offline
post #9 of 14 (permalink) Old 06-09-2011, 07:38 PM Thread Starter
my understanding is the 1500 seal is made of a shaft that spins the opposite direction and does not work.
As for mile the odometer stopped working at 245000+ Im guessing it has 260 or 270.
Doesn't the seal in a can cause other problems?
post #10 of 14 (permalink) Old 06-09-2011, 07:39 PM Thread Starter
also any idea how to get the old one out provided I find a seal?
GL1200 shifter oil seal leaking ! glassman Goldwing Technical Forum 3 05-13-2011 04:11 PM
gl1200 crankshaft seal walkabout Goldwing Technical Forum 5 01-29-2011 09:47 PM
GL1000 Front crankshaft seal leaking SPC Goldwing Technical Forum 4 09-19-2010 01:45 PM
GL1200 Crankshaft seal discontinued Feetup Goldwing Technical Forum 3 08-13-2010 04:29 PM
84 GL1200 gear shift seal leaking Conley Goldwing Technical Forum 2 08-02-2009 12:23 AM
