post #1 of 11 (permalink) Old 06-12-2011, 07:55 AM Thread Starter
coolgto67's Avatar
Send a message via Yahoo to coolgto67
Hello wingers what would make the right turn singnal light stay on all the time it does not flash the left one works fine.
coolgto67 is offline
post #2 of 11 (permalink) Old 06-12-2011, 08:05 AM
RB
RB's Avatar
Send a message via AIM to RB
sure it's not the marker light..both should be on when the bike is on and maybe your turn signal is just out.
1976 GL1000 RED rebuilt SOLD
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 A sold
1997 1500 SE SOLD
1999 1500 SE SOLD
1998 1500 SE..RIDING
FAIR WINDS,
RB
RB is offline
post #3 of 11 (permalink) Old 06-12-2011, 09:00 AM Thread Starter
coolgto67's Avatar
The marker lights are on in the front but the turn light on the trunk stays on all the time and the turn indicator on the dash stays on also. Is there a flasher unit on the bike like on cars.
post #4 of 11 (permalink) Old 06-12-2011, 09:28 AM
galaxyhunter's Avatar
Model: 2000 Aspencade
You said the trunk stays on. Does the front turn come on at all? Or is it on all the time?. If it doesn't come on at all, Then change the bulb. I had car at one time that if a turn signal bulb burnt out, That side would not flash. This could be the same thing.
Carl
Honorary Rhino
Astronomy is my main MONEY PIT, But my GW is a close second.
old bikes:
71FX Super Glide
86 Aspencade
galaxyhunter is offline
post #5 of 11 (permalink) Old 06-12-2011, 09:44 AM Thread Starter
coolgto67's Avatar
The front is on all the time so is the turn indicator on the dash and the trunk light.
post #6 of 11 (permalink) Old 06-12-2011, 09:52 AM Thread Starter
coolgto67's Avatar
Could the switch be sticking on the right side.
post #7 of 11 (permalink) Old 06-12-2011, 11:23 AM
If the bulbs are "On all th time" then I would look at the flasher. The switch just connects the circuit, The flasher regulates the blinking.
Carl
Honorary Rhino
old bikes:
71FX Super Glide
86 Aspencade
post #8 of 11 (permalink) Old 06-12-2011, 02:54 PM Thread Starter
coolgto67's Avatar
Ok this is weird it doesn't do it when i am riding it went off when i took offand got down the road but when i stoped and turned off the bike then turned on the key the right side stayed on again.Could that have something to do with the self canceling system buy the way where is the flasher unit.
post #9 of 11 (permalink) Old 06-12-2011, 03:56 PM
I looked in the Service Manual for my '00 Aspy. There is no "Flasher" unit. There is a Relay that is located under the trunk. There are two relays mounted side by side. The one for the turn signals is on the right side. The one on the left is for the hazzard signals. They are the same relay. Try switching relays to see if that does anything.
Carl
Honorary Rhino
old bikes:
71FX Super Glide
86 Aspencade
post #10 of 11 (permalink) Old 02-16-2013, 03:05 PM
Model: GL1500 Aspencade
I have same problem with left side turn signal indicators. Like that 2 days. So there is only one relay for both sides. My parking indicators switch is sticking. So I don't use it any more. Can that be a connection?
GL1500 Aspencade 1995 is offline
GL1500 turn signal switch twistedbiker69 Goldwing Technical Forum 9 09-21-2012 03:48 AM
GL1500 Turn Signal Connectors Brew Goldwing Technical Forum 3 07-19-2012 11:39 PM
Turn Signal lenses, GL1500 DOC1500 Goldwing Technical Forum 2 01-21-2012 12:48 PM
89 GL1500 Turn Signal Ghost_Rider Goldwing Technical Forum 4 09-18-2011 08:31 PM
No turn signal GL1500 coolgto67 Goldwing Technical Forum 3 11-15-2009 08:48 PM
