post #1 of 13 (permalink) Old 07-24-2011, 11:24 PM Thread Starter
hopefully someone here has had to remove the fuel tank from an aspencade 1984 gl1200....is there an easier way to do this than having to remove the back tire as the haynes manual describes for proper removal....i would really rather not have to do that...but i will to get that tank clean.it has been sitting for 3 yrs. and it smell like varnish in there....also some cleaning tips would be greatly appreciated....just started on her and i will definetly need some solid advice to bring her back where she should be.....thanks.
big al beasley is offline
post #2 of 13 (permalink) Old 07-25-2011, 02:17 AM
Gregarious Greeter
SETHAN12's Avatar
Model: GL 1800
http://www.goldwingfacts.com/forums/...s+tank+removal
Hopefully the above thread will help
Yesterday is for memories!
Today is for making memories!
Just livin\' the dream!!!!!
Honor above all else!!!!!
SETHAN12 is offline
post #3 of 13 (permalink) Old 07-25-2011, 02:21 AM
Gregarious Greeter
SETHAN12's Avatar
Model: GL 1800
http://www.goldwingfacts.com/forums/...rusty+gas+tank
Also check this out.
Hope this has been helpful and
SETHAN12 is offline
post #4 of 13 (permalink) Old 07-25-2011, 05:20 AM
rideandslidejim's Avatar
Electrosis Thats the way i did it, worked great, no need to remove the tank. My thread is on here somewhere but i can't find it to give you a link. Maybe some others can help. Here's a before and after pics.
Jim
Body and Bike in southern Georgia,heart and head back in the Del/Mar/Va.
Jim
"Member of lousy spellers of America"
rideandslidejim is offline
post #5 of 13 (permalink) Old 07-25-2011, 05:23 AM
After
Jim
post #6 of 13 (permalink) Old 07-25-2011, 06:18 AM
sctrucker's Avatar
that looks very interesting, i used carb cleaner to get everything loose after i removed the sending unit then used a vacum to remove everything
some of my past rides:
197? hd z90 sold
197? honda 500-4 traded this to get another engine for my first wing after the belt went within like 100 miles of buying it
1976 gl1000 dressed with all vetter sold
1985 gl1200 interstate sold
1986 gl1000 naked (traded this one to get the work done on my gl1200 sei
1983 magna vf750c (sold)
2010 vw trike (still trying to complete this one)
randy coffee
sctrucker is offline
post #7 of 13 (permalink) Old 07-25-2011, 07:37 AM
fgh
Model: GL1100 Aspy
In your mechanical aptitude is good Electrostatic Rust Removal is in expensive, doesn't involve any chemicals that tree huggers object to and is as effective as anything else. Google it and you'll get lots of hits describing the procedure.
DO NOT KREEM THE TANK. These coatings will cover the intake screen and stop gas flow.
fgh
\'83 Aspy
\'83 GS750ES
fgh is offline
post #8 of 13 (permalink) Old 07-25-2011, 02:04 PM
blackknytecnc's Avatar
Year: 1985
Model: 1985 GL1200 LTD
That's exactly what I did. Bought a gallon of that B-12 stuff, filled the empty tank with it, let it sit, took a piece of 1/2" square tubing, duct taped on a flux brush to it, scrubbed the tank with that, took a piece of 1" pipe and duct taped that to my shop vac to pull out all the crumbs... worked great, took about 3 hours, did everything through the sending unit hole.
blackknytecnc is offline
post #9 of 13 (permalink) Old 07-25-2011, 06:34 PM
sctrucker's Avatar
i actually used spray gummout carb cleaner, not the smartest thing to do but it worked and i didnt get blown up and the shop vac still works fine
197? hd z90 sold
randy coffee
post #10 of 13 (permalink) Old 07-25-2011, 07:30 PM
As long as you are not in a hurry, electrolsis is safe,non-toxic and very cheap, as long as you have a battery charger.Under $5 for the washing soda and a piece of rod for the anode.
Jim
1980 Goldwing false fuel tank wogdom42 Goldwing Technical Forum 5 05-02-2012 09:04 AM
1984 1200 aspencade fuel problem. justwannaride Goldwing Technical Forum 0 04-24-2010 08:20 AM
secrets to fuel tank removal on '83 Aspencade new-to-wings Goldwing Technical Forum 9 10-29-2008 07:53 AM
Goldwing Fuel Tank Configuration Changes OldWingRider Goldwing Technical Forum 3 06-01-2008 01:50 PM
1984 Aspencade fuel gauge question.... Wendell Goldwing Technical Forum 18 07-29-2005 01:27 PM
