post #1 of 8 (permalink) Old 01-16-2012, 10:30 AM Thread Starter
I'm trying to find a alternator for my 1988 gl1500. Hard to find. My question is, will any other yr alternator work on my 1500. If so are there any changes that have to be made for them to work.
Thanks for any help.
Dave549 is offline
post #2 of 8 (permalink) Old 01-16-2012, 10:38 AM
hummer5205's Avatar
Model: 1996 gl1500 SE
I would suggest after you do all necessery tests & If you find that your alt is shot then Take the alt off & take it to a place that rebuilds alts/starters/Generaters & They can rebuild it for you but if you have a-lot of Lights /electricle accs Then I would get the compufire alt /Ken Hemmings !
All good things come to He who waitith if he workith like hell while he waitith !
hummer5205 is offline
post #3 of 8 (permalink) Old 01-16-2012, 10:49 AM
ALEX BERECZKY's Avatar
Model: GL1500
Dave549 wrote:
...will any other yr alternator work on my 1500. If so are there any changes that have to be made for them to work...
> All model years are compatible (1988 - 2000).
> No modifications required, between different years.
> Ken Hemming does rebuilds, and also sells rebuilt alternators
http://myplace.frontier.com/~hemi-roid/
KEN HEMING 3701 E. 69TH. AVE. MERRILLVILLE, IN. 46410-3963 219-947-4038 hemi-roid@frontier.com
I void warranties
GL1500, 1990SE, 199k miles
Bridgestone Battlax BT45 on front, 41psi
Dark Side #590, 175R16 Austone, 50psi
GL1500, 2000SE, 168k miles,
Dark Side #590, 175/60/16 Dunlop Wintersport ROF, 41psi
KJ6QFZ
ALEX BERECZKY is offline
post #4 of 8 (permalink) Old 01-16-2012, 09:19 PM
Go with hummer and have your alt. rebuilt for approx. $200.00.
The 88s had a good alt. that would last for many miles .
The later models had less quality units installed.
The Crazy 88
machinehead is offline
post #5 of 8 (permalink) Old 01-16-2012, 10:47 PM
Indianawantsme's Avatar
Model: 2012 GL1800
Might be as simple as needing new brushes ,rear bearing, and drive rubber bushings while it is apart.
Steve E.
2012-GL1800- 8200 miles
88-GL1500-124k+ mi. SOLD
78-Honda CB750K- 71k+ mi. -drive to work bike
67-Suzuki 250cc T20-X6 Hustler-fun to ride yet
Pirelli Snow Control 3
Indianawantsme is offline
post #6 of 8 (permalink) Old 01-17-2012, 08:20 AM
Anti-Guru
satan's Avatar
Model: '06 GL1800
The 1988 alternator mounting is slightly different than the later years' mounting, which is why you'll not find many listed.
Your '88 alternator mounts using shouldered bolts. The shoulders on these bolts are used to position the alternator allowing the sealing o-ring to be more-equally compressed.
The later year alternators use dowel pins (OEM p/n 94301-10160 et sim, for the curious) in lieu of the shouldered bolts for the same effect.
That kinda explains the "why" you're not seein many listed.
A good work-around is to either have your unit rebuilt (as presented above) or to modify your mounting situation.Simply over-boring the mounting holes on the later model alternators will allow you to retain your '88's OEM mounting bolts. Some folks have also gone with changing to "normal" bolts to mount a later-year alternator onto these first-year bikes.
While, personally, I prefer to re-bore the alternator's holes a bit, choosing to change the bolts will allow you to "share" spare parts with other 1500 riders without road-side modification...
satan is offline
post #7 of 8 (permalink) Old 01-17-2012, 09:44 AM Thread Starter
Thanks for your infor. After reading your input. I see I have the "normal" bolts w/out shoulders. Again Thank you!
Dave549 is offline
post #8 of 8 (permalink) Old 01-17-2012, 10:08 AM
A new alternator (oem), is 243$ from hdl.parts.
When doing long distance travel,on the 1500 , i have always had a spare with me ! (and used it once 2000 miles from home).
1988 GL1500 Alternator wd8ejc Goldwing Technical Forum 4 09-09-2012 07:45 PM
Wanted Alternator for a 1988 GL1500 Goldwing dex_357 For Sale/Wanted Forum 8 08-17-2010 01:01 AM
1988 GL1500 Alternator Rebuild machinehead Goldwing Technical Forum 4 03-01-2010 01:43 PM
Alternator/Regulator 1988 GL1500 Sandman27 Goldwing Technical Forum 3 06-15-2006 11:30 PM
1988 Goldwing alternator jwg1950 Goldwing Technical Forum 7 11-24-2005 07:22 PM
