post #1 of 25 (permalink) Old 02-05-2012, 11:06 PM Thread Starter
Master Sgt. USAF Retired.
circlepilot's Avatar
Model: 1999 GL1500SE 74,000 miles.
Volt Meter, GL1500
IMHO: I consider the Gold Wing to be the "Cadillac Coupe De Ville" of motorcycles. All the "bells and whistles"but,...no type of charging indicator? I installed the Kuryakyn 4219 this weekend. I was immediately challenged as to where to install it. I called my cousin in Florida and asked where he installed his on his 1800? Convenience doesn't work for me. I did some "soul searching;" some measuring and some feeling around. One #21 hole; a little soldering and a two "zip-ties" later; my installation was complete and most of all, looked (again IMHO) factory. The installation instructions called for a "hot wire" and a "circuit ground." I tapped into the right, fairing "recognition light strip." the task took me about an hour; once I decided where to put the meter.
Next? An analog oil pressure indicator.
Norm
The physics of two wheel operation frees the inner soul.
Norm
circlepilot is offline
post #2 of 25 (permalink) Old 02-05-2012, 11:45 PM
Silicon Sam's Avatar
Model: 1997 GL1500 SE
I bought the same thing from CycleMax, only the all black version. I am anti-chrome in the cockpit.
But I'll likely mount mine in the same place as yours. But you're right, there's not many choices on where to mount such a small item. I have a Hopnel pocket on the left that covers the area where the CB is...
1983 GL1100 Interstate Black
Silicon Sam is offline
post #3 of 25 (permalink) Old 02-05-2012, 11:57 PM Thread Starter
I thought about that also; "anti-chrome in the cockpit." I can assure you...the first time I get a glare...Tape and "black wrinkle paint" will cure that.
Norm
Norm
post #4 of 25 (permalink) Old 02-06-2012, 04:15 AM
Senior Guru
GWNorman's Avatar
Model: GL1800, GL1500, GL1200
That looks nice circlepilot. They must have changed the design, that one looks different to the one I have. The chrome face kept falling away from mine, it was a well known issue.They may have fixed that on your version.
GWNorman is offline
post #5 of 25 (permalink) Old 02-06-2012, 04:44 AM
Yeah, I'm still here
Rudy's Avatar
Model: AmericanSportworks LMLSV
Send a message via Skype™ to Rudy
I have the black one for non-glare and it is mounted on a small aluminum bracket I made for it where the fader control used to be.
It is aimed at me but I never see it directly (nor do I wish to). It is designed so that I see it as a heads-up display off of the inside of my windscreen just below my field of view. There is now a 2nd GPS between the thermometer and the voltmeter since this picture was taken.
BTW, that is a two piece plastic case. my front cover snapped loose once on some bad road on the way to N3 and I just filled the inside back with Goop and taped it closed it again overnight. Never a problem since.
Rudy
"People give up their privacy for the chance at a $.10 off coupon!"
(quoted from conf. at ODNI)
Rudy is offline
post #6 of 25 (permalink) Old 02-06-2012, 08:16 AM
Just another ORF!
Dusty Boots's Avatar
Model: 92 1500 Aspencade
I can attest to how well Rudy's 'Head up Display' works. I was riding behind him on our way over to Snorebaby's and I could see it reflecting in his windshield, while I was a good 200' behind him.
Myself, I have the black one attached to the backside of the fairing's inner wall, off to the right of the ignition panel and left of the removable inner cover, where it is dark and any amount of daylight/glare won't 'washout' it's display. I can see it out of my peripheral.
The area circled is where I have it located
- just another Rider
Dusty Boots is offline
post #7 of 25 (permalink) Old 02-06-2012, 08:30 AM
Rudy's Avatar
Yep. There are only two things I want to see in my heads up display... my Kuryakyn LED voltmeter and my SmartLight monitor LED.
You can see the info, instantly, day or night without taking your eyes off the road.
Rudy
Rudy is offline
post #8 of 25 (permalink) Old 02-06-2012, 01:20 PM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
i have a black one installed on the right vertical face of the brake m/c,works great and easily seen,plus it has a sensor which dims it at night so that it doesn't bother you
neoracer is offline
post #9 of 25 (permalink) Old 02-06-2012, 04:03 PM Thread Starter
Thanks for all the comments. I did a short night run and there was no adverse glare or distraction from the indicator lights. If I can get a break in the morning freezes, I'll do a day run and check for "sun glare."...Wait till you see the oil pressure indicator. (Hopefully)
Norm
post #10 of 25 (permalink) Old 02-06-2012, 05:40 PM
OldSchool_IsCool's Avatar
Year: 1982
Model: Interstate
Here's where I mounted mine on an 1100...
Bruce
Current Bikes:
74 CB750 K4
77 CB550 K3
82 CM250C
Past Bikes:
What?? SELL a bike??
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
PGR since 2011
OldSchool_IsCool is offline
GL1500, very discreet volt meter ( where is charly) dj norm Goldwing Technical Forum 5 07-07-2012 08:02 PM
gl1500 Volt, temp,gear position, meter combo DOC1500 Goldwing Technical Forum 60 04-24-2012 05:42 PM
Volt meter addition, GL1500 the Rovin Rev Goldwing Technical Forum 24 12-04-2011 06:22 PM
Volt./Amp Meter for GL1500? LSC9901 Goldwing Technical Forum 5 08-22-2010 06:05 PM
Volt Meter Panel or Hold the Volt Meter surapong General Motorcycle Discussion Forum 2 12-14-2005 11:50 PM
