post #1 of 3 (permalink) Old 03-15-2012, 09:28 AM Thread Starter
perry518's Avatar
Model: 1992 gl1500 aspencade
Rear brakes are sticking on 92 aspencade clean the caliper already decided to clean mc and lines po never replaced fluid whats needed to be removed to get mc out thanks
perry518 is offline
post #2 of 3 (permalink) Old 03-15-2012, 12:44 PM
ALEX BERECZKY's Avatar
Model: GL1500
perry518 wrote:
...whats needed to be removed to get mc [Master Cylinder] out thanks
> Remove:
-Front Lower Cowl
-Lower Body Panels, 2 each (rt side)
-Passenger Foot Rest (rt side)
-Exhaust Header (rt side)
-Heat Shields (around MC)
-Battery box (maybe, to remove the rear MC fluid resevoir)
I void warranties
GL1500, 1990SE, 199k miles
Bridgestone Battlax BT45 on front, 41psi
Dark Side #590, 175R16 Austone, 50psi
GL1500, 2000SE, 168k miles,
Dark Side #590, 175/60/16 Dunlop Wintersport ROF, 41psi
KJ6QFZ
ALEX BERECZKY is offline
post #3 of 3 (permalink) Old 03-15-2012, 02:43 PM Thread Starter
perry518's Avatar
Thanks for the reply gonna tackle it this wknd
perry518 is offline
Rear Brake Master Cylinder Question-GL1500 JackfromCT Goldwing Technical Forum 6 02-27-2011 08:18 PM
Rear Master Cylinder Removal???? ramtough_63 Goldwing Technical Forum 4 01-02-2010 04:01 PM
GL1500 rear brake master cylinder Motosickle Goldwing Technical Forum 1 07-09-2008 09:26 PM
GL1500: Rear Master Cylinder Foosman(5) Goldwing Technical Forum 1 03-07-2007 11:11 PM
GL1500 Rear Master Cylinder nickstas Goldwing Technical Forum 1 08-19-2006 05:21 AM
