post #1 of 7 (permalink) Old 04-13-2012, 10:19 PM Thread Starter
fishblock's Avatar
Model: 1989 gl1500
I'm thinking about upgrading my radio soon by adding an amp.
I'm just wondering what amps are being used, Where the amp is mounted
and how to wire input to the amp.
I have a couple of PAC speaker to rca converter boxes from some of my earlier days in car audio - I was thinking of using the front speakers to the pac and removing the rear speakers all together.
I use to have an "old school" Linear Power amp that was small in size, wish I still had it......
GWRRA Texas District
TX X2 member
1989 gl1500
fishblock is offline
post #2 of 7 (permalink) Old 04-14-2012, 01:07 AM
Right winger's Avatar
Year: 1985 1984
Make: Honda's 3
Model: GW Aspy & LTD, LTD 2
Check this out . I'm thinking of looking into it myself
http://www.crutchfield.com/p_206PX1K...12PX100-2.html
1984 Aspencade Premium Beige Metalic..... Right Wing
1985 LTD Sunflash Gold 85,530 Grace Brown...... Left Wing
A Bird can\'t fly on one wing
That\'s why I have three wings
And another 85 LTD, LTD 2 Sunflash Gold Grace Brown.... Tail Wing
With three wings I believe I can fly
AL
Right winger is offline
post #3 of 7 (permalink) Old 04-14-2012, 02:19 AM
pwhoever's Avatar
You can do a lot better than the money you would spend on that kicker amp. A popular one is the Pyle PLMRA400 4 ch amp and can be found for around $50. That is the one I am using however my setup is a little different. Another member that is using the Pyle amp is Rudy. He did a writeup on how he added an amp to his bike and there is some good info HERE. Whatever you do, especially if you add an amp, run new speaker wire to the speakers and upgrade the speakers. The stock ones aren't that great and throwing more power to them will be a waste of time.
Mike K.
97 Aspencade - Pearl White
Darkside Rear Tire- Austone 175R16
Double Darkside Front-Battl-Ax BT-45 130/70-18
2014 starting mileage- 60106
Darkside #1659
pwhoever is offline
post #4 of 7 (permalink) Old 04-14-2012, 06:48 AM
Year: 1985 1984
Make: Honda's 3
Pyle PLMRA400.........HUH you get what you pay for BS in, and BS out, KICKER is the way to go. I will agree that youshould change out the stock speakers. But if you are afraid to spend a little money then stick with what you have.
AL
post #5 of 7 (permalink) Old 04-14-2012, 10:33 AM
dabeam's Avatar
I have another thread running with a similar question. Is anyone using the Pyle amp? What makes for a quality amp? Will this fit under the seat?
One needs a 4 ch amp, correct?
I would like to mount an amp under the seat, so I am thinking smaller. I don't want to take up too much trunk space.
dabeam is offline
post #6 of 7 (permalink) Old 04-14-2012, 02:26 PM Thread Starter
fishblock's Avatar
Model: 1989 gl1500
Well from what I've seen under my seat, I don't think an amp is going to fit. plus you want some air space around the amp so it wont overheat. I'm thinking in the trunk, or left saddlebag. I'm thinking about using the Polk 5" front speakers and ditching the rear all together, and use a 2 channel amp. With a helmet on I cant hear the rear anyways.
My main thing is getting an amp that will not kill my electrical system
TX X2 member
1989 gl1500
post #7 of 7 (permalink) Old 07-14-2015, 11:05 PM
Year: 1995
Make: GL1500
Model: Aspencade - 20th Anniversary
Thumbs down Upgrade isn't going as planned...
Iíve got a dilemma and need some helpÖ Iíve got a 1995 GL1500 and finally decided to upgrade the stereo. I bought a BOSS Audio B65N High Level to Low Level Converter to down convert the audio for a Clarion EQS746 1/2 DIN Graphic Equalizer with Built-in Crossover. From the EQ Iím driving a Pyle PLMRA400 400-Watt 4-Channel Waterproof Marine/Car Amplifier.
For now Iíve only got the front speakers hooked up. They are a pair of Polk Audio DB501 5-Inch Coaxial Speakers.
The sound sounds like crap. If I bypass the Converter and EQ and go directly into the AMP with a High Level signal, the sound still sounds like crap. There seems to be no bass and the sound is very high
If I hook up the DB501 speakers to the normal system the sound good or normal.
Iíve checked and double checked all the wiring. All is good. I ran all new speaker wire and power wire for the EQ and AMP.
Is it something simple like a bad amp? Thoughts?
tjernagel is offline
Speaker and amp install, GL1500 TnVol Goldwing Technical Forum 15 07-05-2012 06:42 AM
GL1500 noise filter install and oil gauge install questions.... gaspredator Goldwing Technical Forum 4 06-30-2011 10:31 PM
Need Markland Floorboard/ Heel & Toe shifter GL1500 install instructions... ka9nyn Goldwing Technical Forum 3 05-25-2011 10:15 PM
For sale: J&M Audio Components JumboJet For Sale/Wanted Forum 5 01-27-2011 09:19 PM
J & M audio elite speakers xharleyman Goldwing Technical Forum 5 01-18-2009 09:37 PM
