post #1 of 13 (permalink) Old 04-29-2012, 08:29 PM Thread Starter
Ihave a 2002 1800 goldwing. I am wanting to change out the engine coolant. Service manual says remove right side pocket.{check} Did that. Remove radiator cap. {check} Did that. Then remove drain plug that is located just on the up side of oil filter. {check} did that. I am getting no discharge of coolant from the drain??????? WT. Dont know what is going on here.There is no mention of a pipcock valve or anything that needs to be opened. Any ideas for me about whats going on. Thanks. Dave
miloman is offline
post #2 of 13 (permalink) Old 04-29-2012, 08:53 PM
Disfunctional Nimatode
Dancinbear's Avatar
can you see coolant in radiator thru cap? Is there coolant in reserve tank? Has the bike been running hot? There may be an obstruction at the drain hole.... you may want to fish around in the drain hole with a wire to see if anything breaks loose and releases the coolant. Or pour some water in the filler cap and see if it comes out the bottom.
Don't want a deal with alot of flibiddy-flab or mumbo-jumbo...........
2003 GL1800 Illusion Blue
Dancinbear is offline
post #3 of 13 (permalink) Old 04-29-2012, 09:04 PM Thread Starter
engine run temp is in normal range. coolant in tank is normal. just nothing from the drain. i did fisf around a bit with a small screwdriver to see if pluged but did not break anything loose. so i guess next question is this because the screwdriver blade did hit something without going past the plug threads. how deep should something go into the plug hole before hitting botom, so to speak?
miloman is offline
post #4 of 13 (permalink) Old 04-29-2012, 09:11 PM
Gregarious Greeter
SETHAN12's Avatar
Model: GL 1800
Make sure you took out the right bolt
Should have been a sealer washer that came off with the bolt.
Yesterday is for memories!
Today is for making memories!
Just livin\' the dream!!!!!
Honor above all else!!!!!
SETHAN12 is offline
post #5 of 13 (permalink) Old 04-29-2012, 10:08 PM Thread Starter
yes, im very sure of that one. thanks
miloman is offline
post #6 of 13 (permalink) Old 04-29-2012, 10:19 PM
If it has never been changed it could have crud built up in the drain. It won't hurt to poke something up in there.
[SIGPIC]
post #7 of 13 (permalink) Old 04-29-2012, 10:56 PM Thread Starter
iam nor ifihas ever been changed. I know the previous owner never canged it. so it is possible it has never been done. i do know that it has the green colored antifreeze in it. i do not know what type it came with from new.
miloman is offline
post #8 of 13 (permalink) Old 04-29-2012, 11:33 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
Did you remove the radiator cap?
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #9 of 13 (permalink) Old 04-29-2012, 11:43 PM
Still Learning
newday777's Avatar
1800 coolant change w/ clicky pics.
http://www.pbase.com/fredharmon/coolant
Stu
Previous bikes
post #10 of 13 (permalink) Old 04-29-2012, 11:44 PM Thread Starter
yes, followed all correct procedures to drain antifreeze
miloman is offline
2002 1800 Goldwing radio problems Hed Goldwing Technical Forum 8 12-29-2012 10:26 AM
2002 1800 goldwing miloman Goldwing Technical Forum 4 05-17-2012 11:22 AM
Change Antifreeze A B C Keith Davidson Goldwing Technical Forum 1 09-25-2011 01:08 PM
2002 GOLDWING 1800 MOTORTRIKE AIR PRESSURE FOR TIRES WIZARD0520 Goldwing Technical Forum 6 09-26-2009 05:06 PM
2002 GL 1800 GOLDWING EML MARTINIQUE TRIKE JANET B For Sale/Wanted Forum 1 07-29-2007 06:30 AM
