post #1 of 8 (permalink) Old 05-06-2012, 08:50 AM Thread Starter
Model: GL 1500 SE
Send a message via AIM to davepyer Send a message via MSN to davepyer
Hi folks.
I have been tidying up the rear end wiring on my friends 95 1500 wing.(UK spec bike).
The PO had made a bit of a mess adding all the extra tail lights so I have been re-wiring it all.
I have everything working as it should except the top box (trunk)spoiler light. It has 3 wires running to it. Black, orange and yellow.
Now, when I connect the spoiler light direct to a battery it works fine. I connect the black toearth then the yellow to+and I get a tail light. Then I also add the orangeto + (so yellow and orange are live)and I get a brake light.It also works when I connect one wire at a time (yellow tail, orange brake).
Now the problem. When I connect the spoiler light to the bike circuits via a 3 way plug (brake/tail and earth)I have spliced into the Stop/Tail light circuits in the trunk boxI only get the brake light working. If I disconnect the orange (brake) wireIget the tail light working.So I can have the light as a Stop light or tail light but not both.I have triple checked my wiring and it all seems right and everything else is working correctly.
The spoiler light was only wired in with 2 wires when I started work on it so I think the PO had the same issues.
DoI need any extra wiring bits? Any help will be very welcome.
Regards Dave
davepyer is offline
post #2 of 8 (permalink) Old 05-06-2012, 09:37 AM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
The rest of the brake lights are off when this happens, and go on when you hit the brake lever/pedal?
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #3 of 8 (permalink) Old 05-06-2012, 10:15 AM Thread Starter
Model: GL 1500 SE
Yip.
Everything works fine. All tail lights work. Pull brake and all brake lights come on. Even the trunk spoiler light will work as either a stop or tail light (depending on which wire I connect) but not both.
davepyer is offline
post #4 of 8 (permalink) Old 05-06-2012, 03:40 PM
On the SE there is a special "RELAY" , adding apr. 9 volts to tail ligth and 12 volts for stop . The "high accessory ligth" should be connected to that !
SMEDEN(=the blacksmith) is online now
post #5 of 8 (permalink) Old 05-06-2012, 04:14 PM Thread Starter
Model: GL 1500 SE
Thanks Smeden. Yes, I have that relay and system on my 2000 SE (US spec) but it is not on my friends bike (UKSpec). Ithink the led light has been added at some point. The only thing I can think of that may be causing this problem, is that there is not enough voltage to light the LED Brake light. I think I read somewhere they will only work within a certain voltage range. As he is changing the timing belts at the moment, we can't start the engine. With all the otherbrake lights on (6 bulbs)the drain on the battery might be taking to much power. I will charge the battery and remove some bulbs to see if that makes any difference.
davepyer is offline
post #6 of 8 (permalink) Old 05-06-2012, 04:32 PM
Clwydian's Avatar
Model: gl1500sen
Send a message via MSN to Clwydian
Vary the voltage to vary the brightness.. goodness an analogue tail/stop light. Probably extends the life of the tail light mode tho...
Carl (GW0TQM)
GL1500SEN 1991 imported from France
NT700v-7 Deauville
exNT650v-2 Deauville
exVT125 shadow
(check the 'goldwing web' app on Google play store)
Clwydian is offline
post #7 of 8 (permalink) Old 05-08-2012, 04:03 PM Thread Starter
Model: GL 1500 SE
Just an update on the light problem. I got in touch with big bike parts who sell the light and they confirmed that I do indeed need a little wire loom to make it work as a stop tail light. Part No 13-307.
Thanks to everyone for the help.
davepyer is offline
post #8 of 8 (permalink) Old 05-08-2012, 05:58 PM
gaswing's Avatar
Yes it's a wire with two diodes soldered end to end that you need. The way the US models work is that 6 volts goes to the LED strip through a module (which isn't fitted to UK models). When you hit the brakes, 12volts is sent through the module which gives full brightness.
Before BBP and Electrical Connections started selling a piece of wire with the diodes (for the GL1500 and later the 1800), we used to have to buy the diodes and solder them into the running light wire ourselves, and run another wire from the brake circuit.
Post number 10 in this thread has a wiring diagram for the spoiler, posted by sandiegobrass:
http://www.goldwingfacts.com/forums/forum6/46458.html
gaswing is offline
Spoiler Light on GL1500 woodworks Goldwing Technical Forum 18 08-06-2012 02:12 AM
Stop light tail light led, GL1200 tb4511 Goldwing Technical Forum 7 05-23-2012 11:28 AM
WTB 1200 trunk tail/stop light Winesap7 For Sale/Wanted Forum 4 09-03-2010 01:43 AM
FOR SALE 1981-83 GL1100 rear stop/tail light housing and lens jmelche2 For Sale/Wanted Forum 0 08-02-2009 09:23 AM
GL1500 Spoiler Light wjessen For Sale/Wanted Forum 18 10-16-2008 04:18 PM
