post #1 of 12 (permalink) Old 05-11-2012, 12:25 PM Thread Starter
Hi folks,
I'm working on my project, an 86 GL1200A, I noticed a small oil leak from the shifter seal and replaced that last night.
Today I noticed some white smoke from the front of the engine. It seems that the oil leak was dripping onto the left-side exhaust headers. Is it safe to just let that burn off normally, or is there some way I need to clean it?
Thanks!
\'86 GL1200 Aspencade -- Project / Tinker Bike
\'96 Shadow VT1100c -- Daily Rider
marbin drakon is offline
post #2 of 12 (permalink) Old 05-11-2012, 12:27 PM
Passed On, R.I.P.
scotterichmond's Avatar
Model: 75 GL1000, 81 GL1100i
brake clean is a good degreaser
If you can't afford to do it right the first time,
You sure can't afford to do it the second time.
Life is a long series of choices, some good some not
[SIGPIC][/SIGPIC]
1975 GL1000 48000 mi
and 1981 GL1100i 42500mi
scotterichmond is offline
post #3 of 12 (permalink) Old 05-11-2012, 12:31 PM
White smoke?
What's it smell like?
post #4 of 12 (permalink) Old 05-11-2012, 12:32 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
If a lot built up, clean it. Just fresh little bit, your choice.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #5 of 12 (permalink) Old 05-11-2012, 12:33 PM
Still Learning
newday777's Avatar
Or are the exhaust manifold nuts loose?
Stu
Previous bikes
post #6 of 12 (permalink) Old 05-11-2012, 12:46 PM Thread Starter
Wow, that was fast.
It's definitely just the oil, I recognize the smell from spilling oil changing it in my car. Plus I can see where it is coming from. Not major smoke, just little wisps that start when the exhaust headers get hot enough.
Thanks for asking me to check those bolts though, noticed a small exhaust leak from the clamp where the left muffler joins to the pipes off the engine. (PO installed Jardine slip-on mufflers)
post #7 of 12 (permalink) Old 05-11-2012, 01:09 PM Thread Starter
I appreciate your help. I imagine I'll be needing a lot of it as I move down the list on this bike.
After needing a hammer to get the oil drain plug off and watching what is basically black paint come out, I'm operating under the assumption that nobody has done maintenance on this thing in a long time. Runs and rides though which I guess is good for a 26 year old bike.
post #8 of 12 (permalink) Old 05-11-2012, 01:56 PM
Still Learning
newday777's Avatar
When you changed the oil, had you warmed up the motor and oil to running temp? Cold oil is always thicker and the gunk settles to the bottom of the crankcase. Yes old oil can get real grungy if not change regularly, if left to set for a long period, it'll get very thick and gooey from the exhaust gases/carbon deposits that mix in the oil.
Run a qt of Marvel Mystery oil or Seafoam in the fresh oil change for an easy 200-300 miles(continuous easy riding, low rpms, lots of shifting through the gears up and down) and then change the oil and filter again while it is still hot to clean out the gunk in the motor. Run that oil for 500 miles and change it again.
Run Delo400LE 15w40 oil as a lot on this site do. It's a diesel motor oil with great results over many miles of touring use from Canada to SoCal and east, no modifiers to cause clutch slippage and it's only $13/gal at Walmart.
Stu
Previous bikes
post #9 of 12 (permalink) Old 05-11-2012, 02:05 PM
ceasefire49's Avatar
Year: 1984
Make: Goldwing Interstate 1200
Model: 1984 1200 I with many add ons
good advice here.
Never argue with an idiot. They will only bring you down to their level and beat you with experience every time.
ceasefire49 is offline
post #10 of 12 (permalink) Old 05-11-2012, 02:05 PM Thread Starter
Thanks for the advice, newday. I should have specified that "black paint" referred to the color not the consistency. The old oil came out rather easily since I drained it with the engine warm.
I will definitely try some Seafoam in the crankcase when I get to working on it in full swing next week. I think I'll pick up several filters and gallons of that oil and do a couple of 500 mile oil changes after that as well.
Shifter seal replacement. gumbyred Goldwing Technical Forum 4 08-12-2011 03:41 PM
New GL1200 shifter oil seal part # glassman Goldwing Technical Forum 2 05-14-2011 10:44 AM
Shifter seal replacement GL1500 alannnn Goldwing Technical Forum 5 10-30-2010 03:36 PM
1500 shifter shaft seal replacement GreggC Goldwing Technical Forum 3 09-28-2009 08:54 AM
GL1500 Shifter removal for seal replacement Jack Joyce Goldwing Technical Forum 6 12-23-2006 12:18 PM
