post #1 of 24 (permalink) Old 05-14-2012, 02:40 PM Thread Starter
Model: '92 GL1500
My 1500 has been acting up when I put it in reverse for a couple of months. Sometimes it did not want to disengage to allow bike to start if I cut it off. I would have to play with the lever for several minutes to get a "nuetral" light, allowing the bike to start. Today I went to put it in reverse and it did nothing. No light indicating it is in reverse, and when I pressed the starter bitton it would not move. Any ideas what to check?
Wingrider59
Wingrider59 is offline
post #2 of 24 (permalink) Old 05-14-2012, 03:40 PM
Anti-Guru
satan's Avatar
Model: '06 GL1800
This will most often be related to the revese lever switch.
the reverse lever switch is located beneath the left inner fairing and rides on a little cam that the reverse lever causes to rotate as the lever moves.
When dirty, the reverse switch acts exactly as you describe
satan is offline
post #3 of 24 (permalink) Old 05-14-2012, 03:49 PM
Anti-Guru
satan's Avatar
Model: '06 GL1800
REFERENCE: http://www.goldwingfacts.com/forums/....php?id=129996
Good thread on the switch including a photo of the switch itself:
satan is offline
post #4 of 24 (permalink) Old 05-14-2012, 05:50 PM Thread Starter
Model: '92 GL1500
Thanks for the info and picture! I will try cleaning switch first.
Wingrider59
post #5 of 24 (permalink) Old 05-14-2012, 06:00 PM Thread Starter
Model: '92 GL1500
Can anyone tell me how to remove inner fairing to gain access to the reverse switch? I need to clean it.
Wingrider59
post #6 of 24 (permalink) Old 05-14-2012, 09:06 PM
grambo's Avatar
where is the bolt to hold the pulley on??
91 GL1500
91 Electraglide
Ask the wrench god 1st!!
grambo is offline
post #7 of 24 (permalink) Old 05-14-2012, 09:26 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
Wingrider59
Do you have a repair manual for your bike? That is your #1 tool you need.
This should have been asked in your first post on reverse same with the last question. This clutters up the forum and makes it hard to know what info has been given you already.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #8 of 24 (permalink) Old 05-15-2012, 07:54 AM
Anti-Guru
satan's Avatar
Model: '06 GL1800
Grambo --- the bolt is a hex-head that is in pivot point of the reverse lever... (the cover on the reverse lever slides off to reveal the head of this bolt)
satan is offline
post #9 of 24 (permalink) Old 05-19-2012, 11:12 AM
Send a message via MSN to koly
i had this problem also a year ago i also changed the reverse relay under the seat, i haven't had a problem since
koly is offline
post #10 of 24 (permalink) Old 05-27-2012, 05:14 PM Thread Starter
Model: '92 GL1500
O.K. I tried contact cleaner on the switch( actually I sprayed it without removing plastic), I checked my fuses. Still no reverse. What's next?
Wingrider59
GL1500, NO REVERSE THE BLADE Goldwing Technical Forum 27 06-20-2012 03:22 AM
GL1500 Stuck in reverse, 1995 Gold wing maff Goldwing Technical Forum 11 06-12-2012 04:54 PM
reverse for 85 1200 wing dgoins Goldwing Technical Forum 3 04-09-2011 11:39 PM
Reverse not working - '98 1500 Wing Whitey Goldwing Technical Forum 5 06-20-2009 11:56 PM
Reverse your 'wing Clarkins General Motorcycle Discussion Forum 12 08-08-2007 02:22 PM
