post #1 of 12 (permalink) Old 05-15-2012, 07:43 AM Thread Starter
Redmanstl's Avatar
Model: 1983I,1981I,
hello all, how and the H do ya get the tank out of the frame?
Thanks Cheers.
Redmanstl is offline
post #2 of 12 (permalink) Old 05-15-2012, 08:03 AM
Wingin Again's Avatar
Model: 1983 GL1100I
Hi Redmanstl,
Welcome, when you say tank off the frame, are you meaning the the false tank on top or the actual fuel tank that is tucked down under?
Wingin Again is offline
post #3 of 12 (permalink) Old 05-15-2012, 08:08 AM
rideandslidejim's Avatar
If you are talking about the actual fuel tank, if it like a 1200 you have to take most of the rear of the bike apart, a major job.
Why do you want to remove it ?
Jim
Body and Bike in southern Georgia,heart and head back in the Del/Mar/Va.
Jim
"Member of lousy spellers of America"
rideandslidejim is offline
post #4 of 12 (permalink) Old 05-15-2012, 09:35 AM
Jason's Avatar
If it's the actual fuel tank you need to remove, like Jim says it comes out the back of the frame. There are a couple of recent thread with photos showing what needs to be removed to get the tank out.
Jason
Jason is offline
post #5 of 12 (permalink) Old 05-15-2012, 04:38 PM
OldSchool_IsCool's Avatar
Year: 1982
Model: Interstate
How to remove the False Tank (aka Shelter):
http://www.goldwingdocs.com/forum/vi...f=11&t=101
How to remove the ACTUAL tank:
http://www.goldwingfacts.com/forums/...00+remove+tank
Welcome to the site, BTW!
Current Bikes:
74 CB750 K4
77 CB550 K3
82 CM250C
Past Bikes:
What?? SELL a bike??
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
PGR since 2011
OldSchool_IsCool is online now
post #6 of 12 (permalink) Old 05-15-2012, 08:37 PM
guardian's Avatar
your wing was built "around" the fuel tank.. and must be removed through the rear.
guardian is offline
post #7 of 12 (permalink) Old 05-15-2012, 11:58 PM Thread Starter
Redmanstl's Avatar
Model: 1983I,1981I,
Hey Thanks chaps for the run down.
Think im gonna try that Evapo Rust, one gent spoke about, And then if all else fails then Looks likewe will birthing a tank out the bum.
Tires, Tank, Starter, Rear Master Cylinder, Fork seals, Andcalipers..hope i dont get much deeper
so anybody have some pics on the single holly carb instead of the four Keihin's?
I will have some progress pics soon.
post #8 of 12 (permalink) Old 05-16-2012, 04:51 AM
TBear's Avatar
Model: 83 GL1100 Aspencade
You will become fairly convinced it doesn't come out for awhile before you finally do get it out, kind of like a Chinese Puzzle.
TBear is offline
post #9 of 12 (permalink) Old 05-16-2012, 06:37 AM
Check out useing electrolis method i used.
Jim
www.goldwingfacts.com/forums/forum1/106276.html
Jim
post #10 of 12 (permalink) Old 05-17-2012, 09:43 AM Thread Starter
Redmanstl's Avatar
Model: 1983I,1981I,
ya rideandslidejim, I never thought to do that thanks for the heads up, I have played around with that method before when i was making ahho generator.
However i did pick up some Evapo rust and it seems to be working ok, not as fast as my usual method of muriatic acid, crap load of bb's, and a whole lota shaken.
I have a bikeRally im trying to get to onMemorial weekend so i have eight days, to get it back togetherand test ride before going 120 miles@70mph.
" but this is not my first rodeo" i do this almost every year with some bike.
And with all the things i have to do its like having Goldwing Hanukkah.
Gas Tank Removal blue gl1000 Goldwing Technical Forum 5 05-15-2011 11:08 AM
Gas tank removal? cjbear11 Goldwing Technical Forum 5 06-11-2009 05:27 PM
Gas tank removal Zypher412 Goldwing Technical Forum 3 08-21-2008 10:12 PM
Gas tank removal shoe Goldwing Technical Forum 6 12-10-2007 10:07 AM
gas tank removal johnwing Goldwing Technical Forum 5 07-01-2007 07:47 AM
