post #1 of 7 (permalink) Old 05-28-2012, 05:48 AM Thread Starter
Hi
Just a question on usage as the owners manual does not even seem to mention the 'outlet' button on the compressor controls as far as i can see.
I just want to use the compressor to inflate my tyres and although probably obvious the manual doesnt seem to really describe (GL1500SE).
I have a long hose connected to compressor outlet in pannier and to the Tyre valve.
I expected to then press the outlet button with increase or decrease to inflate tyre.
If I do this nothing happens, but if i use as if I was doing suspension i.e P.Check with increase or decrease then it does. The manual intimates that with hose connected it is bypassing the rear suspension. But if this is how iit works then whats the Outlet button for ?
be very grateful if someone could enlighten me and just describe how I should be using the outlet to inflate the tyres.
Thanks.
Nyme 1998 GL1500SE and 2001 F6C Valkyrie
Nyme is offline
post #2 of 7 (permalink) Old 05-28-2012, 06:42 AM
Mickey Koz's Avatar
Model: F6B
Hi There Nyme. You have to have the key in the "park" position for the compressor to work.
Mickey Koz is offline
post #3 of 7 (permalink) Old 05-28-2012, 06:54 AM Thread Starter
Thanks for reply Micky,
I know this must sem a bit of a numpty query but be good to make sure I am clear before I tour.
I had been using on ACC key location where it works for suspension but obviously not for outlet then.
So with airline connected to the outlet and key on P :
If I then press P.Check and increase or decrease is that pumping the suspension still or bypassing to the tyre ? So is the screen pressure display showing tyre pressure or suspension when doing this ?
and if I press outlet it does indeed operate the compressor thanks, but does not show any pressure figures on display. Is this correct, outlet button just inflates things but does not show pressures?
Nyme is offline
post #4 of 7 (permalink) Old 05-28-2012, 06:58 AM
Token Canuk
96aspencade's Avatar
Model: 1996 SE
Many of us (well I do anyway) just carry a small plug in compressor that is much easier to use.
Retired Paramedic - 35 yrs
DD # 1138
30,000 miles - Formosa,
'96 GL 1500 SE - 260,k km
'83 Shadow 500
'70 Kawasaki KE-125
'?? Suzuki 80
96aspencade is offline
post #5 of 7 (permalink) Old 05-28-2012, 07:15 AM
Spondulas's Avatar
Bike compressors are essential for suspension adjustment and expensive to replace, so I also carry a small compressor (about fist size) that I use for everyday needs. Paid about $ 10 for it at the local Walmart. I have alligator plugs on it so I can connect directly to the battery (requires less wire/hose length to reach either end) and I can run the bike while using it so the battery doesn't run down. If I should happen to burn it out, no big loss.
Spondulas is offline
post #6 of 7 (permalink) Old 05-28-2012, 07:37 AM
Bellboy40's Avatar
Model: GL1500SE Candy Spectra Red
Nyme, here is the page from the owners manual showing how to use the outlet button.
Larry
-- Albert Einstein
Bellboy40 is offline
post #7 of 7 (permalink) Old 05-28-2012, 08:07 AM Thread Starter
Thanks a lot for that.
It's interesting that I have just checked this page number in my owners manual and it is not the same.
This explains everything I needed to know. Interesting points so far about carrying spare small compressors, but I just wanted to ensure I knew how to use it for emergency inflation of a wheel after a puncture.
Cheers
Nyme is offline
GL1500 Air Compressor help deanthebean Goldwing Technical Forum 8 03-21-2012 06:56 PM
Air hose for GL1500 rear bag compressed air outlet flw General Motorcycle Discussion Forum 1 09-03-2010 09:06 AM
GL1500 air compressor tadhgk Goldwing Technical Forum 4 07-20-2010 03:22 PM
Air compressor GL1500 glgreg Goldwing Technical Forum 6 11-11-2009 06:56 PM
air compressor outlet wing commander Goldwing Technical Forum 8 06-23-2006 06:43 PM
