post #1 of 6 (permalink) Old 06-07-2012, 05:01 PM Thread Starter
My '93 1500SE is getting terrible mileage - about 30mpg. This contrasts with 3 years ago when it was 40-42mpg. I have been running regular gas for 4 years, based on the recommendations of some owners. I now am beginning to run ethanol-free premium. Any suggestions on what I can/should do to improve my mileage? Thanks
carp59901 is offline
post #2 of 6 (permalink) Old 06-07-2012, 05:10 PM
Your engine is only 9:1 compression so it isn't going to run better on anything higher than 87 which is most likely the recommended octane by Honda. So 89 octane and higher is a waste of money. Several factors effect fuel economy Riding habits, tire inflation, riding environment, engine tuning, air cleaner, plugs, etc. one thing for sure mileage from 40-42 to 30 definitely isn't a fuel issue. It's a bike issue or a rider issue or both. 10% ethanol fuel has blamed for as much as a 10% reduction in fuel economy . I have not seen that reduction though. Still at 10% you should still be in the high 30's running 87 10% ethanol in the bike.
JIMBO83 is offline
post #3 of 6 (permalink) Old 06-07-2012, 05:12 PM
Senior Guru
agnogel's Avatar
regular serviceing is importent plugs filters ect also you may be in need of a carb sync at this stage, adding some fuel system cleaner will also help like seafoam as the jet diamaters can be reduced over time with varnish build up ,dragging brakes is another one ,
Peter
agnogel is offline
post #4 of 6 (permalink) Old 06-07-2012, 05:19 PM
"adding some fuel system cleaner will also help like seafoam "
+1
JIMBO83 is offline
post #5 of 6 (permalink) Old 06-07-2012, 05:20 PM
Plugs, filter, seafoam, tire pressure, brakes dragging, various accessories like taller windshield, wings, extra weight...
chris in va is offline
post #6 of 6 (permalink) Old 06-07-2012, 06:25 PM
Whiskerfish's Avatar
Check your brakes to make sure something is not dragging. As they get older and build up corrosion inside the calipers they do not always release properly and a dragging brake will suck gas quickly.
Whiskerfish
1975 Nekid Noisy and Nasty
1975 Nekid in pieces parts
Whiskerfish is offline
GL1500 used to have good fuel mileage ,now extremely poor cycledutchman Goldwing Technical Forum 41 07-08-2012 12:21 PM
POOR GAS MILEAGE GL1500 Jrogers Goldwing Technical Forum 25 06-22-2012 12:30 PM
GL1500 used to have good fuel mileage ,now extremely poor cycledutchman New Members Introduction Forum 17 06-19-2012 09:37 AM
GL1500 Interstate Poor Mileage Sakryn Goldwing Technical Forum 3 05-03-2012 11:31 AM
GL1500 Poor Mileage mlsa Goldwing Technical Forum 15 02-03-2009 01:37 PM
