post #1 of 22 (permalink) Old 07-19-2012, 12:42 PM Thread Starter
97 1500SE Have grinding noise from engine/transmission even when idleing at 2000 RPM and gets worse when in gear (does not matter which gear) Tech was no help.
Thought of R/R engine/trans with possibly wrecked bike but do not knowwhich year are interchangeable?
arnejagoldwing is offline
post #2 of 22 (permalink) Old 07-19-2012, 04:10 PM
knklehd1's Avatar
Model: gl1800
As just doing a engine swap myself I would stick with a 97-00 as the 4th gear problem was fixed.And should be a bolt to bolt.
I have done so much with so little,I can do anything !!
02 gl1800
knklehd1 is offline
post #3 of 22 (permalink) Old 07-19-2012, 07:17 PM Thread Starter
Thanks, curious as to what year your bike?
post #4 of 22 (permalink) Old 07-19-2012, 07:28 PM
knklehd1's Avatar
Model: gl1800
94a I bought it with a bad trans swapped the engines the only thing now is the cc isn't working just have to work it out thats all.Like I said a 97-00 is bolt to bolt it's not that hard of a job it's time consuming and take pictures lots of them did I say take a lot of pictures it helps when putting things back together.
02 gl1800
knklehd1 is offline
post #5 of 22 (permalink) Old 07-19-2012, 07:50 PM
saws-n-wings's Avatar
Model: 1000 1100 1200 1500 1800
Welcome to the forum arnejagoldwing.Is there any other problems other than the noise?Metal flake in the oil?
saws-n-wings is offline
post #6 of 22 (permalink) Old 07-20-2012, 03:56 PM Thread Starter
No metal noticed, sound is more like growle (possibly something loose inside) this noise was present when I bought it used. Thought it was normal with wings, had no previous experience with it The noise is (louder now)audible mechanic was able to hear it but unable decipher without taking apart. also did not notice any power lose as I am driving but economy has dropped about 5miles/gal. Just had both tires changed spine was lubed, final gear lube R/R . drive shaft no defect.
post #7 of 22 (permalink) Old 07-20-2012, 04:00 PM Thread Starter
Thanks, will take lots of pics, if decided to R/R.
post #8 of 22 (permalink) Old 07-20-2012, 06:24 PM
Send a message via AIM to Saddle Time
Also, Check the belt tensioners bearings, could be going bad try to isolate with a stethoscope
Harry
"NOT BRAND LOYAL, JUST TWO WHEEL LOYAL"
Ret Army, Inf. PM HATM#879 Acgl
Rolling Thunder "All Gave Some Some Gave All"
Gone, but not forgotton
78&79 Wings 94 Aspy(Current 93 Aspy)
Street Glide & Dyna. Buell
Suzuki, Yamaha, Kawasaki, other Hondas
Triumph,BSA,Bultaco
Saddle Time is offline
post #9 of 22 (permalink) Old 07-20-2012, 11:35 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
welcome to the forum arnejagoldwing
Alternator dampers hardened will cause growl, have you checked them? There are 4, @ $4 each.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #10 of 22 (permalink) Old 07-21-2012, 07:09 AM
Derek Hackett's Avatar
A friend of mine has had to change his 1991SE UK spec engine due to transmission problem on 4th gear 70000 miles. He purcgased a 1999 engine with low miles (£1100) but as it was a short engine requiring carbs, alternator, starter changing over and he has encountered some problems that you and anyone else should be aware of.
1st there are extra hoses normally fitted on the new unit that did not come with the engine that are not on the older unit. further investigation shows this as a pairs system that are fitted to some bikes for emmission purposes.To overcome this He has had machined plugs to fit the openings on the engine, we hope this will overcome this. 2nd he started to bolt on the starter motor and broke the front case as the bolt from the 1991 was slightly longer than the new unit. He has now had to remove front engine case off and change for the older one. He is awaiting a new gasket at this point and will commence with fitting next week. If we come into any other problems I will post for you.
Hope this helps,
Derek
Keeper of the Magic! Keeping the Dragons on Top!
Derek Hackett is offline
GL1500 ENGINE SWAP TO NEWER YEAR??? millhouse1 Goldwing Technical Forum 15 02-05-2012 03:42 PM
WTB -GL1500 Right saddle bag & left engine guard kshbennet For Sale/Wanted Forum 4 07-02-2011 08:59 PM
GL1500 Tach raises & lowers without engine increase or decrease When_in_gout Goldwing Technical Forum 2 05-05-2011 07:31 AM
can engine year of manufacture be determined from engine number compo For Sale/Wanted Forum 1 05-01-2008 02:02 PM
06' Transmission jumps in&out of gear Dusty Roads Goldwing Technical Forum 4 09-12-2007 07:41 AM
