post #1 of 7 (permalink) Old 07-22-2012, 08:38 AM Thread Starter
seabeechief's Avatar
Model: '08 GL1800
Need help replacing hi-beam headlight on '08 GL1800. I didn't have much luck searching the forum and tech board. So far, it looks like a monumental undertaking. Any assistance will be appreciated.
Chief
Combat Vets Asso. San Antonio
PGR San Antonio & Austin
Darkside #1609
seabeechief is offline
post #2 of 7 (permalink) Old 07-22-2012, 09:11 AM
If you remove the fairing pocket you can reach in and change the bulb.
[SIGPIC]
post #3 of 7 (permalink) Old 07-22-2012, 09:12 AM
Gregarious Greeter
SETHAN12's Avatar
Model: GL 1800
Need to take out the two fairing pockets. Very tight in there so I hope your hands are small. If not, find a small handed person.A little time and a lot of patience also is helpful.
Yesterday is for memories!
Today is for making memories!
Just livin\' the dream!!!!!
Honor above all else!!!!!
SETHAN12 is offline
post #4 of 7 (permalink) Old 07-22-2012, 05:46 PM Thread Starter
Model: '08 GL1800
Thanks guys! I appreciate the help. First, I lied! Lying is nothing new for me but getting caught so quickly is not normal.
It's the low beam. I had so much trouble getting the connector unplugged that I thought I was doing something wrong and I was afraid I was going to break it. I'll give it another go tomorrow.
Before I removed my head from my a$$ and realized it was the low beam that was bad , I did remove the faring pocket on the right side. That was AFTER I removed the "Wing" wind thingy brackets anda piece of plastic trim in order to get the faring pocket out.
Learning new tricks at this stage of my life is not nearly as much fun as it used be. One small scratch and I look like I've been inknife fight with OJ Simpson.
"Cruiseman" has a pretty good video on changing the low beam lamps.
http://www.youtube.com/watch?v=Rilk32i2V7s
Thanks again for your help. Be safe.
Chief
Darkside #1609
post #5 of 7 (permalink) Old 07-22-2012, 05:51 PM
Gregarious Greeter
SETHAN12's Avatar
Model: GL 1800
Low beams are simple. Pull off the rubber boot, unclip (only on one side, because it is hinged on one side) pull out the bulb and replace.
Watch when replacing the rubber boot. There is an arrow on it that should be pointing upward.
Good luck and patience is always helpful.
SETHAN12 is offline
post #6 of 7 (permalink) Old 07-22-2012, 06:13 PM Thread Starter
Model: '08 GL1800
Patience! That's the missing ingedient. Do I buy that by the gallon or the bushel?????
Chief
Darkside #1609
post #7 of 7 (permalink) Old 07-23-2012, 05:04 AM
Gregarious Greeter
SETHAN12's Avatar
Model: GL 1800
I usually have to buy it by the barrel
SETHAN12 is offline
GL1800 low beam headlight replacement Oneoldrider Goldwing Technical Forum 10 10-03-2012 10:43 PM
Replace low beam headlight on gl1800 Lorenzo99 Goldwing Technical Forum 4 08-08-2011 07:36 PM
How do you Replace Right Engine Beam pds110 Goldwing Technical Forum 8 08-11-2010 04:54 PM
GL1800 replace the left high beam KC5TF Goldwing Technical Forum 2 04-29-2010 09:02 PM
008 GL1800 Headlight low beam scuba57 Goldwing Technical Forum 6 09-08-2008 05:25 AM
