post #1 of 3 (permalink) Old 08-24-2012, 09:33 AM Thread Starter
just purchased a 01 goldwing 1800. will be putting on trike kit ("training wheels type") and need a shifter mod. electronic or other option. My question is on the main shaft out of the "drivecase" what is the degree of rotation travel to shift gears?
If I engineer a custom solution for my needs I'd need to know this.
Thanks.
Also, any recomendations for the trike add on? (Tow-Pac, Trigg, .....???)
krazylegz1 is offline
post #2 of 3 (permalink) Old 08-24-2012, 09:49 AM
JDuggan's Avatar
It's hard to say the amount of turn on the gearshaft as each bike is a little different depending on wear and mileage. You would probably want to measure it on your own 1800 to be certain.
Joe Duggan
JDuggan is offline
post #3 of 3 (permalink) Old 08-24-2012, 09:58 AM
You would probably have to find the engineer that designed it to get that spec.
[SIGPIC]
GL1800 Transmission Repairs - what else should be done? Paul C Goldwing Technical Forum 4 10-03-2012 07:12 PM
GL1800 Transmission whine wrinkledwrider Goldwing Technical Forum 5 05-15-2012 10:53 AM
GL1800 Transmission skipping MikeM1 Goldwing Technical Forum 3 10-10-2009 07:09 PM
GL1800 TRANSMISSION WHAMMY Goldwing Technical Forum 60 12-27-2008 12:40 AM
05 GL1800, transmission issue tsdubu Goldwing Technical Forum 12 07-08-2008 02:26 PM
