post #11 of 17 (permalink) Old 11-01-2012, 11:10 AM
DrifterTex's Avatar
Year: 1998
Sweet, I do beilieve I am ready to install HID headlights. I have replaced my running lights with HID's and I am very happy with hem. I just need to readjust the beam on them as they seam to angle toward the side more than I would like. I want them facing a little more to the front. With the headlights and running lights I should be able to see pretty good at night....as if I ever ride at night. hahaha
Texas Winged Horny Toads
NRA Life
PGR # 183546
Boy Scouts of America
Darkside # 1114
Iron Butt Association #45601
1998 GL 1500 SE 72,000 miles **Pegasus**
2006 Suzuki Burgman 26,000 miles
DrifterTex is offline
post #12 of 17 (permalink) Old 11-01-2012, 07:16 PM
Grand Goat's Avatar
Model: 1989 GL1500
Grand Goat - did you change the lens also?
No I did not change the lens. At the time I purchased my set, Cyclemax did not have the offer with the newer lens . Had they, I would have changed the lens.
Word of mouth from a couple of my friends say the newer lens has a better reflector setup. Don't know it is true or not, just what I heard.
Work's a pain, then I ride, Life is Good!
89 GL1500 Wine Berry
175000+ and still going strong.
PGR Member #152800
Warriors' Watch Rider
GWRRA Member
Grand Goat is offline
post #13 of 17 (permalink) Old 11-01-2012, 08:24 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
Yes the newer lenses put out a better light pattern. I have worked on a 97 old style and had my 99 next to it in garage and out on the road. By far the newer is better, just with halogen bulbs, so you will get more light with HID set up in them too as there is not going to be breakup of Light beam through the clear lens as compaired to the defused old style lens as the reflectors inside the newer lights do the focusing of the light beams along with the hood over the bulb to bounce rearward the outward facing beams toward the reflector.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #14 of 17 (permalink) Old 11-01-2012, 08:34 PM
William_86's Avatar
Model: GL1500 Aspencade
any automotive HID kit will do just fine just make sure its bi-xenon H4, you dont have to spend that much from cyclemax.
William_86 is offline
post #15 of 17 (permalink) Old 11-20-2012, 11:00 PM Thread Starter
tnoort's Avatar
Model: '98 1500 SE
Right then..............you guys persuaded me! Am installing the HID kit I rec'd today from Cyclemax.
One question for you guys who have already installed this kit. Where exactly did you guys place the ground wires from the ballasts?
Cheers, as always!
T.
Yessss..........I may be paranoid, but keep that to yourself - you just NEVER know who may be listening!
tnoort is offline
post #16 of 17 (permalink) Old 11-21-2012, 05:38 AM
Originally Posted by tmdriverwannabe View Post
Havent seen anyone mention this either, the 98-2000 headlights require shims under the new bulbs if installing aftermarket bulbs..If you do not install those shims it can cause the new bulbs to be too close to the plastic and can cause melting, so please be aware of this...I have a 93 SE with 95/105 watt h4 bulbs and they work amazingly well, i bought them off ebay for almost nothing and they do not have external ballasts or anything. If your being flashed while on high beams you should be able to adjust that down with the knob on left side of fairing, hope this helps!!
Working on Lopeha's 1500 I found 1 of the headlight connectors melted, it had a 100/60 watt bulb in that socket.
Cheers, as always!
T.
I put an HID kit in Lopeha's bike, I attached the ground wires to the radiator bolts on the outside of the frame. Bad news for you is you have to remove the lowers to get to them.
[SIGPIC]
post #17 of 17 (permalink) Old 11-21-2012, 01:38 PM
mr irrelevant
tmdriverwannabe's Avatar
Model: 2009 GL 1800
Like u Dave, was kinda worried about the melting issue, i read other peoples threads on here before installing those hi watt headbulbs....I had opportunity while doing some other things bout 3 wks ago and check mine out, they are just fine, no melting at all with the 95/105 bi xenon h4 bulbs in there. Bike has roughly 25000 miles on it since the installation also...
Mark
Previous bikes..
76 goldwing gl1000
82 suzuki gs750
83 goldwing gl1100 Interstate,sold jan 2011
93 GL1500 SE purchased 12/2010 with 73k,now over 106k traded in this may.
Current ride is a 09 gl1800 level 3
Wild Rhinos Iowa Chapter
GWRRA #343274 Chapter A Black Sheep Squadron
IOWA PATRIOT GUARD
Now an honorary Newfie!! We have kissed the Cod, downed the Screech, and shouted "Long may your big jib draw!" so are now members of the Royal Order of Newfoundland Screechers.
tmdriverwannabe is offline
Headlight Bulbs 1500 FeButter Goldwing Technical Forum 19 08-30-2012 10:38 PM
Headlight bulbs replacement on a 1500 Psalmist Goldwing Technical Forum 10 10-04-2010 12:02 AM
HID Bulbs Ogrebro Goldwing Technical Forum 12 06-15-2009 12:26 PM
PIAA HID/Xenon Plasma bulbs ridgeline Goldwing Technical Forum 10 06-12-2007 01:25 AM
88 1500 headlight bulbs tlc Goldwing Technical Forum 1 04-22-2006 02:51 AM
