post #1 of 4 (permalink) Old 02-17-2013, 01:06 PM Thread Starter
onewing's Avatar
Model: 2010-Gps
1800 Auxiliary Acc.
Hi, I read on one of the forums the 1800 has 2 auxiliary acc. connections.Would someone be able to tell where they are located. Thanks in advance. Ben
onewing is offline
post #2 of 4 (permalink) Old 02-17-2013, 02:46 PM
Check on the fuse panel beside the battery. There are two screw terminals there, one is +, the other ground, for your one and only accessory terminal. Fused at 5 amps, so no heavy duty stuff on this one.
Previous bikes: Honda 150 Dream, Royal Enfield Bullet,Norton Atlas,Suzuki 750 Waterbuffalo, 79 gl1000,07 gl1800
wingfart is offline
post #3 of 4 (permalink) Old 02-17-2013, 03:35 PM Thread Starter
onewing's Avatar
Model: 2010-Gps
Ok thanks Wingfart, I guess I'll have to install a relay and small fuse block to make room for more then one acc.
onewing is offline
post #4 of 4 (permalink) Old 02-17-2013, 03:50 PM
There is also the accessory connection under the left fairing pocket where an aux. power outlet is usually connected and there is one other on some apparently that is under the shelter on the right side. My 08 had it, have not been under there on the 010.
[SIGPIC]
my acc an profile richr Test Forum 17 03-13-2011 08:33 AM
GL1500 acc terminals Big John .25 Goldwing Technical Forum 11 08-06-2009 05:03 PM
Acc. terminal chiefcherokee Goldwing Technical Forum 12 04-17-2009 09:53 PM
Acc. Lights pete(r) General Motorcycle Discussion Forum 7 09-02-2006 10:40 AM
acc papa grizzly Goldwing Technical Forum 4 03-18-2006 07:36 PM
