post #1 of 9 (permalink) Old 03-21-2013, 02:31 PM Thread Starter
Model: 1983 GL 1100
1983 Honda Goldwing Aspencade wobbles
Yes I have a 1983 Honda Goldwing Aspencade GL1100A that every now and then has a almost uncontrollable wobble at low speed, I would appreciate any help.
ritz50 is offline
post #2 of 9 (permalink) Old 03-21-2013, 02:44 PM
wingpilot96's Avatar
Model: 08 1800HPNA
Had a similar issue with my 96' SE, It was the steeringhead bearing that were my problem. Had them replaced and no further issues
2008 GL1800 HPNA - 18,500+ miles
1988 Bunkhouse Camper
wingpilot96 is offline
post #3 of 9 (permalink) Old 03-21-2013, 03:27 PM
Model: 1976 LTD (X2) (two apart in VIN)..... 1976 GL1000 Sulfur,... 2008 Pearl White
Could also be worn forks, loose/bad swing arm or wheel bearings, bad shocks, or even the tires.
Bill
77Pinto is offline
post #4 of 9 (permalink) Old 03-21-2013, 04:12 PM
killer driller
jon jay's Avatar
Model: 1999 1500se,1986 gl1200
I had same problem,changed my tires and problem went away.
jon jay is offline
post #5 of 9 (permalink) Old 03-21-2013, 05:04 PM
Official "Cheeky Plonker"
chilidawg's Avatar
Year: 1980-81-82-83
Model: 80thru83-GL1100STDASPENSTATE
I've never had to deal with head bearings on my GW, but I'm assuming it has a tapered roller bearing and I know from previous machines that that's exactly what you get if you tighten them too much, kind've more like an oscilation, than a wobble?
"In IndyCar, no one makes money. It's just great, pure racing!".
Sebastian Bourdais, 4 time. World champion.
chilidawg is offline
post #6 of 9 (permalink) Old 03-22-2013, 12:49 AM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
There are many posts on this subject. Use the forum search tool.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #7 of 9 (permalink) Old 03-22-2013, 09:11 AM
sirkitrider's Avatar
Model: 1984 GL1200 Interstate with Voyager Trike Kit; 21K showing on the OD
Stu, good to see you posting again. - Sirkitrider
John 3:16
sirkitrider is offline
post #8 of 9 (permalink) Old 03-22-2013, 12:02 PM
fgh
Model: GL1100 Aspy
Mine has an occassional low speed wobble, but I wouldn't call it uncontrollable.
I would:
1. Take a close look a the tires. If either are badly cupped or show signs of damaged belts replace them.
2. Put her on the center stand and check for loosness in the front forks and stem and in the rear swing arm. It is hard to detect when they have wheels mounted to them so check carefully.
My guess if its is uncontrollable is bad or loose steering stem bearings.
Hope this helps!
fgh
\'83 Aspy
\'83 GS750ES
fgh is offline
post #9 of 9 (permalink) Old 03-22-2013, 09:07 PM
tcampbell_nc's Avatar
Model: 1983 GL1100 Aspy
Ritz,
I had the exact same problem on the exact same model. Here is the thread:
83 GL1100A - Front end wobble.
Bottom line:
1. Tires are probably badly cupped. (If you don't know what cupped tires feel like, don't feel bad. I didn't when this happened to me. Find someone who knows bike tires and have them check.)
2. the anti-dive on the front is probably set to the softest position (factory setting), change it to "3" on both sides.
3. Make sure that the rear end is tight. My blown wheel bearing and brake bar bushing was allowing my rear end to make the bike unstable.
4. Listen to everyone's advice here. They are all valid possibilities. Start with the easiest tests first. It can really be a process of elimination. If you know a good bike mechanic, it may be worth a few bucks to let him rule out some of the possibilities. Read my thread above. This is a major safety issue and can tak all the fun out of riding.
tcampbell_nc is offline
WTB 1983 Honda Goldwing Aspencade GL 1100 Speed sensor DJ-Rogue For Sale/Wanted Forum 1 06-05-2012 07:29 AM
1983 Honda Goldwing Aspencade GL 1100 DJ-Rogue Goldwing Technical Forum 2 06-05-2012 07:16 AM
1983 Honda GL1100 Aspencade greatdanedaddy Goldwing Technical Forum 8 04-06-2011 08:57 PM
1983 honda goldwing aspencade oldbiker Goldwing Technical Forum 20 02-05-2010 09:02 PM
1983 1200 HONDA ASPENCADE oldbiker Goldwing Technical Forum 16 04-25-2009 05:02 PM
