post #1 of 6 (permalink) Old 06-28-2013, 08:31 AM Thread Starter
nickwarhead's Avatar
Year: 1983
Model: Goldwing Standard
Brake pedal staying down - 1983 GL 1100
Does anyone know what would keep the brake pedal pressed down on an 83' GL 1100? The pedal does not return to the top after being pressed. The brake seems to work and doesn't lock up or anything, it just does not return. If I pull it up it works again. I don't see anything brake fluid leaking anywhere either.
Previous bikes:
1973 Suzuki TM125
2001 Honda Reflex 250 Scooter
1984 Yamaha Venture Royale
1982 Honda CB 900
1994 Harley Davidson Sportster 1200
nickwarhead is offline
post #2 of 6 (permalink) Old 06-28-2013, 08:40 AM
It aint rocket science
DriverRider's Avatar
Model: The best
Most likely the brake pedal pivot has gotten gunked up. Look where it goes into the frame area and spray with some PB blaster or similar and work back and forth.
Correct fix would be to remove clean and relube.
J.D.
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
If local and need help with a 1500, Valkyrie or ST repair feel free to PM
DriverRider is offline
post #3 of 6 (permalink) Old 06-28-2013, 11:19 AM
Chromo's Avatar
Yep, same happened on my 82 1100 also.
Best to remove, clean, grease, the pivot and lever. It can be a bear to get up in there and work on it. Not much to do but tight space to work in.
For mine I could not get to it well enough to get the lever off at the time.
I pulled the pin and washer off the pivot and working the lever up and down sprayed cleaner all over it from both ends and as working the lever slide it in and out as much as I could. Then once it was working freely and seemed to be clean I smeared grease on both ends best I could and worked it up and down sliding in and out much as I could to work the grease up into the center best I could so the whole pivot was hopefully greased.
Put washer and pin back on.
Been about 3 years now and it still works fine, probably good for another 25-30 years now. LOL
Chromo
I ride for FOOD
82 1100 riding sometimes, Red
Chromo is offline
post #4 of 6 (permalink) Old 06-28-2013, 12:00 PM Thread Starter
Year: 1983
I'll have to give that a try. Thanks!
Previous bikes:
1973 Suzuki TM125
1982 Honda CB 900
post #5 of 6 (permalink) Old 06-28-2013, 05:43 PM
Silicon Sam's Avatar
Model: 1997 GL1500 SE
The pivot rod will probably look like this, or worse...
[/URL]
1983 GL1100 Interstate Black
Silicon Sam is offline
post #6 of 6 (permalink) Old 07-01-2013, 12:42 PM Thread Starter
Year: 1983
Yep it was a bit gunked up. Gave it a good cleaning with WD-40 and it was good to go. Thanks guys!
Previous bikes:
1973 Suzuki TM125
1982 Honda CB 900
1100 brake pedal issue mnbowhunter Goldwing Technical Forum 19 05-09-2013 08:01 PM
Front / rear brake on my pedal 1983 GL 1100 10Man Goldwing Technical Forum 16 01-14-2012 07:31 PM
Brake lights staying on, GL1500 SoftLanding Goldwing Technical Forum 13 11-02-2010 02:56 PM
1983 gw 1100 rear brake pistons gumby Goldwing Technical Forum 5 09-29-2009 07:23 PM
Brake Pedal 83 aspencade 1100 frankenpak Goldwing Technical Forum 5 06-10-2009 07:39 AM
