post #1 of 25 (permalink) Old 12-30-2013, 06:02 PM Thread Starter
Model: 2010
relay for gl 1800
anyone know of a good source to purchase relays for a 1800? Dealership prices are way out of line. thanks james
james1212 is offline
post #2 of 25 (permalink) Old 12-30-2013, 06:11 PM
Model: 1999 goldwing se
Check with cyclemax they have a lot of parts and the prices are good.
RKB53 is offline
post #3 of 25 (permalink) Old 12-30-2013, 06:16 PM
Senior Moment Member
Hanko's Avatar
Model: 2004 GL1800A
If you are looking for the starter relays try these.
"From my post on the GL1800Riders Forum"
Originally Posted by Hanko
I checked with my local internet supplier and the part numbers have changed a little.
SW, STARTER MAGNETIC
(35850-MZ0-J10) (replaces 35860-MCA-701) Price $45.85
(35850-MCA-003) (replaces 35850-MCA-701) Prince $47.17
I did a quick check on E-Bay and most are charging higher for New Old Stock, but the knock off ones are going for under $20 but may not be an exact fit.
Henry
Order 2 of these for the 13's
008 SW, STARTER MAGNETIC
35850-MCA-A61 $29.40
(My local dealer internet price is just over $25 .. click the link)
You will just have to keep the plugs correct since their colors will be the same. Honda keeps changing these numbers due to different suppliers and the two different plug colors, but they are the same part through the years.
techdude2000
2004 GL1800A Dark Red
Yes that is ice on the fender!!!
Darksider # 902
Hanko is offline
post #4 of 25 (permalink) Old 12-30-2013, 06:45 PM
Those relays, if you mean the ones in the relay box, are only $11.58 retail.
[SIGPIC]
post #5 of 25 (permalink) Old 12-30-2013, 07:07 PM Thread Starter
Model: 2010
well that is acceptable but my dealership wants 41 with the tax what dealership can you get them for $12 thanks james
i am looking for the assessory relay under the seat thanks james
cyclemax as well as all the others I have checked all have the same picture for wireing harnesses none show the individual relays Oh well guess i have to pay the man
post #6 of 25 (permalink) Old 12-30-2013, 07:20 PM
Any of them that are not bumping their prices way above retail.
Go to a Honda car dealer and ask for a 39794-SDA-A03 relay.
[SIGPIC]
post #7 of 25 (permalink) Old 12-30-2013, 07:25 PM Thread Starter
Model: 2010
thanks dave are all the grey relays on that bottom row the same?
post #8 of 25 (permalink) Old 12-30-2013, 07:46 PM
Hanko's Avatar
Model: 2004 GL1800A
You are right Dave they are a lot cheaper at the car dealer or via
 Amazon Amazon
Henry
Darksider # 902
Hanko is offline
post #9 of 25 (permalink) Old 12-30-2013, 08:00 PM Thread Starter
Model: 2010
will these be an exact fit?
post #10 of 25 (permalink) Old 12-30-2013, 08:53 PM
wingbiker06's Avatar
Model: 2006 comf/navi.
there are two types of relay in the relay box a 4 pin and a 5 pin. You can find these for sale at any motorcycle parts supplier on the internet. I have found that bikebandit is the one that has most eveything. Look under wire harness to find your relay. Good luck
2006 gold goldwing
wingbiker06 is offline
GL1200 Coil Relay, Solder Stator Wire, Starter Relay beechum1 Goldwing Technical Forum 5 12-23-2011 07:19 AM
Relay Accessorys Relay question keithg64 General Motorcycle Discussion Forum 6 01-20-2010 07:27 PM
Relay's nightwizard40 Goldwing Technical Forum 7 09-22-2008 11:37 PM
Relay #3 legtod2 Goldwing Technical Forum 3 07-13-2008 12:54 PM
1988 GL 1500 Fuse & Relay box, and # 3 relay KENT Goldwing Technical Forum 1 12-11-2007 08:09 PM
