post #21 of 32 (permalink) Old 03-06-2014, 07:55 AM Thread Starter
tfwarner23's Avatar
Year: 2001
Make: Harley Davidson
Model: ULTRA CLASSIC ELECTRA GLIDE - EFI
Send a message via Skype™ to tfwarner23
Originally Posted by NC Aspenwing View Post
TF go ahead and get yours Installed and let me know how it goes.
I got the x-factor last week waiting the Hollywood mufflers to get here now.
If we was a little closer we could help each other out.
The package is set for delivery on Monday, i will install right away. Let me know how the hollywoods sound, I was going to purchase both but (wife said i can do it one step at a time, LOL)
Thomas
OPMC - Our Place Motorcycle Club
ABATE of ND - Board of Director
"Lets Ride Together"
GWRRA - Capital Wing Riders, Chapter C
2001 HARLEY DAVIDSON ULTRA CLASSIC ELECTRA GLIDE - EFI
1995 GL1500SE
Previous Owned
1984 GL1200I
1979 Yamaha 650 Special II
1981 Yamaha XV920R
1984 Suzuki GS1100GKE
tfwarner23 is offline
post #22 of 32 (permalink) Old 03-06-2014, 07:59 AM Thread Starter
tfwarner23's Avatar
Year: 2001
In a way, that is something like the X-tractor that used to be available? My trike came to me with one that the original owner installed.
I once tried a stock chamber but very shortly reverted back as I swear, it just seems to run better at 60-70 mph with it.
I also like the tone.
VROOOOMMMMmmmmmmmmmmmm.................m
To your question, seems to my recollection that I found very quickly that at least one side header needs to be let loose from engine since the exits into the middle chamber or crossover (my X-Tractor) or your X-factor go in at converging angles. Of course, both mufflers will be off.
Arm yourself with new gaskets (4 total) as likely the OEM ones will come out in pieces ....
.... and be prepared for possible broken bolts at the clamps.
I had a couple that were rusted solid, so I drilled those stubs and threads out and resheped the clamps as needed and used longer bolts with plain nuts to pull them up.
Your's looks shorter like the stock chamber, mine requires some extensions for rear muffler mounts as it pushes them back about 3 or so inches.
Also, expect a little louder, but not overly louder tone with a more distinctive growl. More like going from a quiet noise to sporty tone (for lack of a better description).
great information, thank you
Thomas
1995 GL1500SE
Previous Owned
1984 GL1200I
1981 Yamaha XV920R
post #23 of 32 (permalink) Old 03-06-2014, 10:36 AM
It aint rocket science
DriverRider's Avatar
Model: The best
You would be hard pressed to notice any sound difference at idle and only slightly more and deeper tone with OEM tailpipes at normal driving conditions.
As the bike rode away the owner cracked open the throttle and then could be heard 2-3 houses away at high RPM.
J.D.
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
If local and need help with a 1500, Valkyrie or ST repair feel free to PM
DriverRider is online now
post #24 of 32 (permalink) Old 03-06-2014, 10:45 AM Thread Starter
tfwarner23's Avatar
Year: 2001
I am ultimately going to put on the hollywood pipes,
Thomas
1995 GL1500SE
Previous Owned
1984 GL1200I
1981 Yamaha XV920R
post #25 of 32 (permalink) Old 03-06-2014, 10:57 AM
Model: The best
Then tack on slightly more noise and slightly deeper tone.
Wind, stereo and tire noise will still trump anything the bike will produce.
J.D.
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
post #26 of 32 (permalink) Old 03-13-2014, 08:00 AM Thread Starter
tfwarner23's Avatar
Year: 2001
installed the system, sounds great, roads were pretty slippery last last night and this morning so no cracking the throttle, will go for a ride at noon and see what she does, i snapped two header bolts off, one installing and one while i was removing, how hard is the process of removing these?
Thomas
1995 GL1500SE
Previous Owned
1984 GL1200I
1981 Yamaha XV920R
post #27 of 32 (permalink) Old 03-13-2014, 08:19 AM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
Depends if there is any length left sticking out to get a hold of the broken studs with vise grips or not. If not it's pull the head off, drill and easy out. You will have to pull the header off to do the vise grips or head.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #28 of 32 (permalink) Old 03-13-2014, 09:38 AM Thread Starter
tfwarner23's Avatar
Year: 2001
it snapped at the nut, so there is thread left, is it easier to cut it off and then drill and tap?
Thomas
1995 GL1500SE
Previous Owned
1984 GL1200I
1981 Yamaha XV920R
post #29 of 32 (permalink) Old 03-13-2014, 09:43 AM
Still Learning
newday777's Avatar
Originally Posted by tfwarner23 View Post
it snapped at the nut, so there is thread left, is it easier to cut it off and then drill tap?
If there are enough threads to get 2 nuts on to tighten them together then back out the stud or vise grips will be easier.
Drill and easy out will require heads off, that means top end gasket set. Lots more work.
Stu
Previous bikes
post #30 of 32 (permalink) Old 03-13-2014, 09:45 AM
Still Learning
newday777's Avatar
Search
how to remove broken exhaust stud
Stu
Previous bikes
Pucker Factor RobTheHillbilly Fun Forum 12 12-28-2011 08:52 PM
X Factor WTF agnogel Fun Forum 3 03-19-2011 08:37 AM
Torqmaster Hollywood Power Mufflers jodell2 General Motorcycle Discussion Forum 4 03-09-2011 01:21 PM
Torqmaster chamber on GL1500 Fooyun Goldwing Technical Forum 30 05-17-2010 01:21 AM
Visibility....another, perhaps, the only factor..... Cousin Jack General Motorcycle Discussion Forum 46 05-21-2009 10:47 AM
