post #41 of 49 (permalink) Old 08-10-2015, 01:24 AM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
I just did this.
I found a set for $40 on ebay shipped to the house
1200 coils cost just over $100 each new.
Removing the 1500 boots makes the installation fairly easy.
The 1500 boots have to be cut off to be removed they don't unscrew like the 1200s do.
JeffMayfield is offline
post #42 of 49 (permalink) Old 08-10-2015, 01:27 AM
Jeff, does this mean you can quit carrying ice water with you to pour under the fuel tank?
Join us for NASR10 "
SR10 "
Summer Rally #10 at
post #43 of 49 (permalink) Old 08-10-2015, 01:49 AM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
I hope so.
I took it out today it was 95 deg f
Not sure I went far enough to prove that the coils were at fault and not the pulse generators so......................
The bag of water is in the trunk for now.
It does run better
So were is the link to the tutorial on 1500 pulse generator on a 1200?
I would have changed the pg's this winter but I broke the first mounting bolt I tried to turn. I left it that way.
post #44 of 49 (permalink) Old 08-10-2015, 01:53 AM
I will have to point DaveO430 to this post and see what he can come up with.
SR10 "
Summer Rally #10 at
post #45 of 49 (permalink) Old 08-11-2015, 03:20 PM
Model: 1980 1100
Just a final note on my 1980 1100. Did the upgrade and it was plug and play. Might have 5-600 miles on the upgraded coil pack and can say that it was a good change, no ballast resistor like the OEM set was. I have used the V6 stock plug boots that are a little hokey looking but I am not sure if the NGK aftermarket one are OK to use. All I know is my bike is running pretty good right now. Not a rocket but a nice surge when you give it a twist.
tunaboy is offline
post #46 of 49 (permalink) Old 09-16-2015, 10:17 PM
Can these GL1500 coils be used on a GL 1000 set up by keeping the ballast resistor in place and wiring the primary as a stock set up with the resistor. Both the stock coils and the GL 1500 coils seem to be a 2 ohm primary resistance if I am reading the post correctly.
I have used these GL1500 coils on early 80's inline four Hondas with good results in the past, yet these bike are a pulse generator electronic ignition and not points like the GL1000.
I plan on keeping the points on the GL 1000 and just want a coil set up that offer removable/replaceable HT wiring at the coils, as a PO cut the stock GL1000 coils HT wiring and spliced some new leads on there that look pretty sketchy.
Any feedback or experience with the stock GL1000 ignition with stock points using the GL1500 or even the older AW82 GL1100 coils as long as the HT wires can be replaced on the coil would be appreciated.
flyin900 is offline
post #47 of 49 (permalink) Old 09-17-2015, 02:44 PM
ekvh's Avatar
Model: 77/83/85/yup, all of 'em in one
The 1500 coils I have are a shade over 3 ohms. Gl1000 coils are 2 ohms Iirc. So you would be okay with the resistor or about one ohm less resistor.
ekvh is offline
post #48 of 49 (permalink) Old 09-17-2015, 08:03 PM
Thank you,
I will check the GL1500 coils I have in stock and I do have a couple of sets of the AW82's from the early 80's bikes that I believe those are 2 ohms for sure and have replaceable HT wires.
The GL1500 coils are just a little better performance from the 1980 CB's that I have converted.
flyin900 is offline
post #49 of 49 (permalink) Old 11-09-2016, 04:57 PM
JohnnyD's Avatar
Year: 1984
Model: GL1200 Standard
Love it. I should give this a try after I get me stator job finished! Thanks for the insight! JD
Originally Posted by westgl View Post
Went to start my 86' GL1200I Naked, No Start.
Pulled plugs checked for spark at all 4 plugs Nothing.
Checked my coils voltage 12V in, nothing out, on one coil.
When you buy the MP08 GL1500 Coils, I got Three Coils, and Six plug wires they were mounted to the GL1500 coils Mounts (i did NOT use the GL1500 coils Mounts) I only used 2 of the coils and 4 of the Plug Wires.
This gave me One spare coil and Two spare Plug Wires for the shelf.
All for $25.00 to my door.
Thanks, JD
1984 Goldwing Standard (on my 2nd, owned one since new)
JohnnyD is offline
GL1200 will not start - no spark @ plugs giddyupdaddy Goldwing Technical Forum 6 03-05-2014 12:44 PM
GL1200 won't start, no spark Coyote Kid Goldwing Technical Forum 2 06-18-2013 09:58 AM
Need a 4cyl Goldwing mechanic near Pittsburgh pa to Morgantown WV. handyrandy General Motorcycle Discussion Forum 8 09-08-2009 11:02 PM
84 GL1200 start problem 34Mike Goldwing Technical Forum 15 09-17-2008 08:03 PM
2004 goldwing wont start no spark or gas zonaville Goldwing Technical Forum 22 11-18-2005 03:27 PM
