Trying to to finish putting in new LED's all lights minus headlight. Have tryed 3 different electronic flashers with no luck. But if I use one of the standard bulbs in ether the front or back they work fine. So WTF :?
The LEDs don't have enough resistance or load on the flasher so it assumes the bulbs are burned out or missing. So either the flasher will not work or it warns you with quick flashes. I hear tell of a "load balancer" that will add enough resistance to the circuit to cure this. However, I also hear there are issues with the auto cancel with this setup.
73.7K members
