post #1 of 4 (permalink) Old 09-07-2016, 07:15 PM Thread Starter
Year: 1984
Model: GL1200 Aspencade
I'm pretty sure I left the spring seat out when I did the oil change...
I'm picking up one from the dealer tomorrow. I've put about 500 miles on the bike since I did the oil change with Mobil 1. Should I pull the filter and inspect the filter for damage/change it or should I change the oil again?
I'm assuming the oil has been filtered because the spring as long as it hasn't pressed through the filter is ok? The spring holds the filter against the engine block so the oil gets filtered right?
Sent from my Nexus 6 using Tapatalk
Linus is offline
post #2 of 4 (permalink) Old 09-07-2016, 07:29 PM
It's fine the way it is.
So put your new washer in on your next oil change.
Ken Bergen is online now
post #3 of 4 (permalink) Old 09-07-2016, 07:42 PM Thread Starter
Year: 1984
So the oil light on for one second after start-up is normal and unrelated? It never comes on after.
Linus is offline
post #4 of 4 (permalink) Old 09-07-2016, 07:57 PM
You could even leave the filter out (Not recommended) and it would do the same.
fork spring change haroldaugustine Goldwing Technical Forum 13 02-04-2016 01:50 PM
change oil in the fall before storage? or in the spring? A1AKeywest Goldwing Technical Forum 44 10-10-2015 03:54 PM
Found a pretty good seat cusion the other day!!!!! vtxcandyred General Motorcycle Discussion Forum 9 09-13-2011 12:36 PM
WANNABE has a new avatar, she's the pretty on the left tanygaer Miscellaneous Forum 9 12-23-2008 03:08 PM
The Book Says Don't Change the Oil(first change) til 4,000 miles instead of 600miles? gixxerbill Goldwing Technical Forum 3 06-25-2007 04:06 AM
