post #1 of 5 (permalink) Old 09-07-2016, 08:21 PM Thread Starter
Year: 1984
Model: GL1200 Aspencade
GL1200 Aspencade Air suspension questions.
I was previously running about half way up the display front and rear and realized I was probably grossly over in the front. I believe the decal says 6 is the max in the front. I went down to 6 in the front and now there is a lot of travel in the front.
Was the pressure too high?
What do you guys run F/R 1 up and 2 up?
Sent from my Nexus 6 using Tapatalk
Linus is offline
post #2 of 5 (permalink) Old 09-07-2016, 08:28 PM
nwhittemore07885's Avatar
First off set the air to the max (inside the zone indicated for front and rear by the parenthesis on each setting ) with it on the center stand then ride it and see what you think ... its only supposed to be adjusted on stand according to manual but once its set to max you can adjust it minutely once its on its wheels
Sent from my SAMSUNG-SM-N920A using Tapatalk
nwhittemore07885 is offline
post #3 of 5 (permalink) Old 09-07-2016, 08:29 PM
I typically run 3-4 bars on front and just below max on rear . It shows you where to run it
post #4 of 5 (permalink) Old 09-07-2016, 08:42 PM Thread Starter
Year: 1984
3-4 bars is above max on the scale I believe it's only 1 or 2 that being said I had 0 dive in the front end.
Linus is offline
post #5 of 5 (permalink) Old 09-07-2016, 08:52 PM
If you are sure the fluid level and viscosity are correct and you have no leaks, you can set the pressure to max. The problem is, with those bars, you can't really tell what pressure you are running.
Set the TRAC system up a notch if you are getting a lot of dive.
Maximum pressure may cause some leakage past the seals and also may make the ride pretty harsh. With stock springs I kept mine at 2 to 3 PSI and that gave a decent ride. With Progressives, no air is needed.
82' 1100 Aspencade Air Suspension question RockyMt Rich Goldwing Technical Forum 3 06-28-2011 03:44 PM
1982 gl1100 Aspencade suspension questions. Mr Magic Fingers Goldwing Technical Forum 9 05-19-2010 01:08 AM
1984 gl1200 Aspencade air suspension LunaticMark Goldwing Technical Forum 2 04-27-2010 02:06 PM
Aspencade suspension air control valve tricky Goldwing Technical Forum 4 11-19-2006 08:51 AM
Aspencade Air Suspension cardkev Goldwing Technical Forum 1 04-03-2006 01:46 PM
