3Likes
post #1 of 45 (permalink) Old 11-20-2016, 11:51 AM Thread Starter
JohnnyD's Avatar
Year: 1984
Model: GL1200 Standard
Question Stator install on GL1200
I purchased the Randakk's replacement stator. I'm seeking advice from anybody that has done this install themselves...
I've watched Steve's video on this and he makes it looks so easy. The sealing plug doesn't want to fit in fully, easy enough to fit the "circlip." I'm thinking of using some sort of clamp to assist. Ideas?
Also the stator itself does not just slide onto its hub (as shown in video). It is quite a tight fit. I checked the original one too and it's the same. It came off easy enough but would need some encouragement to go back on. I can get it started on the hub lip, just barely with a little grease. I can use slightly longer bolts than the original screws to pull it into place. Is this standard?
Again, any ideas and helpful suggestions are appreciated!
Thanks, JD
1984 Goldwing Standard (on my 2nd, owned one since new)
JohnnyD is offline
post #2 of 45 (permalink) Old 11-20-2016, 12:52 PM
big PIA
MysticFour's Avatar
Year: 1983
Model: GL1200
I had the same things when I installed it on my 84, as far as the plug I used a 3/8 socket ext and tapped around the plug to get it in and seated, imagine its tight so it seals better. I also tapped around the stator flange a little bit, not much to help it slide on until I could get the screw in enough to pull it on
Turned my GL1100 into a GL1200
MysticFour is offline
post #3 of 45 (permalink) Old 11-20-2016, 01:01 PM Thread Starter
JohnnyD's Avatar
Year: 1984
Thanks MysticFour, for the vote of confidence! At least it's not just me!Thanks also for the idea to tap it in. JD
Thanks, JD
JohnnyD is offline
post #4 of 45 (permalink) Old 11-20-2016, 03:33 PM
Others here have said they filed out the hole a little to get the plug in. Maybe a small sanding drum on a Dremmel?
CrystalPistol likes this.
post #5 of 45 (permalink) Old 11-20-2016, 04:04 PM
CrystalPistol's Avatar
I was gonna suggest Vaseline.
Yeah, like just slightly soften and polish the edge of the hole?
...( Candy Spectra Red )
'85 GL-1200 Aspencade
...( Vintage Red )
'74 Triumph T-150V Trident
...( It's a Triple )
CrystalPistol is offline
post #6 of 45 (permalink) Old 11-21-2016, 09:37 AM Thread Starter
JohnnyD's Avatar
Year: 1984
Smile O-ring too thick?
So I tried tapping it in, with a 3/8" extension as suggested. While trying to get the circlip on it slipped out again. Good thing, as I noticed forcing it in damaged the O-ring. Then I compared the O-ring given with the Randakk's stator was much thicker than the stock O-ring (see picture). I later used the stock O-ring and it pressed in smoothly. Good thing I ordered an OEM O-ring for this!
Now that I have struggled with this overnight, I suggest buying the stock O-ring and then there should be no need to file out the opening!
(photo: stock O-ring on left, damaged Randakk's O-ring on right)
Thanks, JD
JohnnyD is offline
post #7 of 45 (permalink) Old 11-21-2016, 09:42 AM
Large Member
wilmo's Avatar
Year: 1994
When I did my Randakks I had the same issue with it being a tight fit. I just used slightly longer bolts to get it started-2 turns each to keep it even and then just finished with the original bolts in a circular motion until it was down all the way. didn't have an issue with the pigtail...
Bike...and Dennis likes this.
Wilmo
Rubber side down!
1994 Goldwing SE
66,440 mi as of Mar 14 2017
Other ride:
2005 Yamaha Majesty 400 (Maxi-Scoot)
wilmo is online now
post #8 of 45 (permalink) Old 11-27-2016, 11:37 AM Thread Starter
JohnnyD's Avatar
Year: 1984
Question Timing belts tension?
A whole lot of work so far...
I love the posts where somebody does this job in 8 hours. I spent 8 hours alone just cleaning up parts!
Question re the timing belts. BTW, I bought Gates T070 belts for $15 each at O'Reilly's. I ordered them over the phone and they had them 7 AM the next morning.
How tight should these belts be? I have a tendency to over-tighten bolts and most other things. How can you measure tension on these?
Mine is a very low mileage '84 Standard (CA model with 24K miles). She cleaned up nice didn't she? All I used was Goop hand soad to clean the parts. And for the purists (I'm one too), I put one of the used valve covers I found in the picture. After this job is done I will install the stock covers. Thanks all!
Thanks, JD
JohnnyD is offline
post #9 of 45 (permalink) Old 11-27-2016, 11:54 AM
Spring tension should be enough. If you suspect your springs are sprung, get some new ones.
http://shop.westernhonda.com/fiche_s...87&fveh=132543
post #10 of 45 (permalink) Old 11-27-2016, 02:10 PM
Model: 84&86 Interstates
Yeah I do. send it back to Randakk's. I installed one of their's last spring. It lasted 137 miles. They'd replace it ONLY after I'd tear it back apart, and send it back to them to test it. The argument I had with them over the phone was very unprintable. Yes, I do know how to use a voltmeter. I even went out and bought a new one to verify that my old one still worked fine. ( it's part of my tool kit that I carry in my bike now)
Poorboy here I come.
purplerider is offline
GL1200 radio install longtime.unknown Goldwing Technical Forum 9 02-23-2012 08:29 PM
GL1200 floorboards - Need install manual wolfmann Goldwing Technical Forum 12 06-12-2010 10:23 AM
GL1200 CB Install WingFlyer Goldwing Technical Forum 3 05-26-2008 12:55 PM
Aerial install on a GL1200 my lifetime Goldwing Technical Forum 2 03-29-2007 07:08 AM
Timing belt install, GL1200 zonk3939 Goldwing Technical Forum 5 07-15-2005 03:48 PM
