6Likes
post #11 of 13 (permalink) Old 01-09-2017, 11:29 PM
Originally Posted by JamesPal View Post
During the winter time I like to change the oil warm. It keeps my fingers warm.
Fingers, hand, arm up to the elbow.
I agree with Dennis. Most service manuals say warm so the oil is mixed up and will carry the contaminants away. I think that is the preferred method. As for the draining overnight I had a bad experience. I had a VW that I drained warm and let it drain over night. Thought that would be a good thing. Changed the oil and started the engine to find no oil pressure. The oil pump got so fry it lost it's prime. Kind of panicked. Already had the filter full before even starting it so I tried removing the filter and run the engine. No luck. It was just not going to prime and I was getting to a point where the lifters were starting to get noisey. I ended up overfilling it by a lot. Let it sit several hours and hit the key to find it had oil pressure again. Drained out the excess oil and all was good again. I know that is unusual but I will never do that on another engine. Especially one that has quite a few miles on it and probably worn oil pump elements. I'm guessing the old pump just didn't suck like it should.
redwing52 is online now
post #12 of 13 (permalink) Old 01-09-2017, 11:50 PM
Oh - THAT guy...
rpeters549's Avatar
Make: 1500
I have always just pulled the drain plug. Warm, cold, whatever. It stays out until I think it is done. Usually I pull it and go have a sandwich and a drink.
Avatar- 1963 Kenskill trailer
rpeters549 is offline
post #13 of 13 (permalink) Old 01-10-2017, 12:35 AM
Certified Slacker
Year: 94
Make: Wing of course!
Model: 1500 SE
IF you are using seafoam in the oil before change, it does need a good 10-15 minute blaster ride to fully warm the oil before draining.
Sludge type material does settle and harden at the bottom of the oil pan -on a car engine- when left overnight after a good seafoam cleaning run
The warm-up will re-liquify the crud, and send it out the drain.
Thats assuming the oil filter doesnt capture all the bad stuff,
which I suppose if we still used rolls of toilet paper as oil filters,,, that would be an issue
short version: Just oil, either temp, just let it drain as much as possible.
Seafoam added- MUST be warm!
Certified Slacker is suffering under the delusion of being an expert... We need more Voltage! IGOR- throw the 3rd switch!!
Not the 3rd switch Master!!
Aloha Tom is offline
I'm pretty sure I left the spring seat out when I did the oil change... Linus Goldwing Technical Forum 3 09-07-2016 08:57 PM
change oil in the fall before storage? or in the spring? A1AKeywest Goldwing Technical Forum 44 10-10-2015 04:54 PM
oil change easy question redz90 Goldwing Technical Forum 11 03-09-2010 11:42 PM
Quick oil change question PapawRAS Goldwing Technical Forum 5 08-18-2009 08:58 PM
First Oil Change Question PA Chuck Goldwing Technical Forum 4 04-11-2009 10:41 AM
