3Likes
post #11 of 20 (permalink) Old 01-10-2017, 08:46 PM
If the drive is over filled it generally leaks out of the top vent.
Yours appears to be leaking both from the input seal and output seal and unless the vent is plugged indicates more serious problems.
redwing52 likes this.
Ken Bergen is online now
post #12 of 20 (permalink) Old 01-10-2017, 10:08 PM Thread Starter
edromero's Avatar
Year: 1990
Make: gl 1500
Model: gl 1500
Originally Posted by edromero View Post
Im not sure how this is supposed to look on my 1990 gl 1500, but m guessing the drive shaft shouldnt be dripping. How badly is this going to hurt my pocketbook?
Pinion bearing is a fairly common issue on these bikes. The final drive holds very little lube. The assembly runs hot and many tend to forget to service them. If you put all 3 together you can understand why the bearing fails. Once the bearing fails the seal can't seal to the shaft as it is moving all over the place. There should be zero play in the input shaft at the final drive. Check that when /if you do the seal. If the shaft moves save the work and replace the bearing.
If the final is not noisy you might just run it and keep an eye on the fluid level. A few drops of oil can make things look pretty messy when mixed with dust and dirt. That would be completely up to you. Also be sure the vent is open. If it is plugged pressure can build internally and push the oil out.
Thank you. How can i go about inspecting the vent? Does it also involve rear end removal?
edromero is offline
post #13 of 20 (permalink) Old 01-10-2017, 10:14 PM
The vent is on the top of the drive, removing the right saddle bag will give you a good look.
post #14 of 20 (permalink) Old 01-14-2017, 10:01 AM
Indianawantsme's Avatar
Model: 2012 GL1800
Edromero: Get in contact with me if you need a different drive. I have a spare that would be really CHEAP for you. Too bad it wasn't in the summer when my daughter was home from Gainesville,Fl.
I have an 1800 now and never did need it.
Steve E.
2012-GL1800- 11k miles
88-GL1500-124k+ mi. SOLD
78-Honda CB750K- 71k+ mi. -drive to work bike
67-Suzuki 250cc T20-X6 Hustler-fun to ride yet
G709 Front- 9600mi and replaced with G851
Pirelli Snow Control 3
4000mi on it so far @36psi and less sometimes
Indianawantsme is offline
post #15 of 20 (permalink) Old 01-14-2017, 12:01 PM Thread Starter
edromero's Avatar
Year: 1990
Make: gl 1500
Model: gl 1500
Thank you i might because I ran into another problem today (see my recent new post)
edromero is offline
post #16 of 20 (permalink) Old 01-15-2017, 09:57 AM Thread Starter
edromero's Avatar
Year: 1990
Make: gl 1500
Model: gl 1500
well I am encouraged by a couple of things:
1) the dripping is minor and 2) the fluid is a light honey color, which makes me think it was changed recently, and which could also mean an overfill situation.
if it IS an overfill, will it eventually just go away once the oil reaches its correct level below the filler?
edromero is offline
post #17 of 20 (permalink) Old 01-15-2017, 10:03 AM
You need to open it up and look at the seals to see where it's leaking from.
post #18 of 20 (permalink) Old 01-15-2017, 06:07 PM
seafoam guru
Year: 94
Model: 1500 SE
Correction to the 1500 rear end fill level is: Level with the bottom of plug, and 4.7 not 4.3 oz to fill it. Sorry Folks went back and read my 94 book.
NO!! Do not wait for the level to go down! Ck it and remove excess if needed.
CrystalPistol likes this.
Aloha Tom is offline
post #19 of 20 (permalink) Old 01-15-2017, 07:17 PM
Just put it on the center stand.
Remove plug.
Let oil run out until it stops.
Job1 done.
It is supposed to be "at" the bottom of the threads.
post #20 of 20 (permalink) Old 01-15-2017, 11:25 PM
seafoam guru
Year: 94
Model: 1500 SE
at/level with same milli-liter~
Not- fluid flowing out because someone did an old style auto shop change and pumped in a bunch, letting it overflow to flush the system...shove the plug in.
Whatever extra stays in = bonus cooling fluid!
Not such a great idea on the Wing~
New GL1000 project, first big problem pidjones Goldwing Technical Forum 8 05-28-2013 06:10 AM
Big Sale on Big Agnes Camping Equipment.... pwhoever For Sale/Wanted Forum 0 11-25-2012 11:50 PM
Big Bike Parts Driving light kit for GL-1500 Problem 3delta General Motorcycle Discussion Forum 8 01-16-2012 08:47 AM
Kendon 'Big Bike' Trailer.... A 1500 is Too BIG.... 77Pinto General Motorcycle Discussion Forum 26 09-17-2011 11:25 AM
