4Likes
post #1 of 37 (permalink) Old 01-10-2017, 11:55 PM Thread Starter
Year: 1989
Model: 1989 GL1500 LE
Crankcase leaks
I've driven over a gutter and bottomed out, now I've got an oil leak from the bottom of the crankcase ! Apart from a major heart transplant, is there an oil additive I can add that will stop the leak ? Hopefully !
jimod is offline
post #2 of 37 (permalink) Old 01-11-2017, 02:30 AM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
Have you located the leak? It may be as simple as a loose drain plug.
Erdeniz Umman is offline
post #3 of 37 (permalink) Old 01-11-2017, 03:59 AM
It would be nice if it was the oil drain plug. If not and the crankcase is cracked there are several repairs tat would be much less troublesome and much much less expensive. Check back with you results. How bad is the leak?
redwing52 is online now
post #4 of 37 (permalink) Old 01-11-2017, 04:46 AM Thread Starter
Year: 1989
Haven't had a chance to get a good look at it yet. It only happened this afternoon. I noticed a patch of oil on the floor under the bike. Enough to make a grown man cry !
The oil was full when I left for a ride this morning so I'll check tomorrow and see how much is left, then I'll know how bad it is........
jimod is offline
post #5 of 37 (permalink) Old 01-11-2017, 05:01 AM
As I said, it could be the drain plug, since it's outer side is not protected it could rotate counterclockwise which means loosening when you bottomed out. Don't ask how I know that.
post #6 of 37 (permalink) Old 01-11-2017, 05:29 AM
Stop crying , and get down an have a look , - ohh you already is down under , - Arent you ? (sorry , - couldnt help myself ).
Seriosli , maybe it is only a loose oil filter ?
post #7 of 37 (permalink) Old 01-11-2017, 08:59 AM
CrystalPistol's Avatar
Ain't nothin' to do but get down there with some cleaning stuff and clean and have a look. Pics and post here would be good, may help to determine if it's a crack or plug and if it's a crack, if it's structural. Could be at a seam as well.
...( Candy Spectra Red )
'85 GL-1200 Aspencade
...( Vintage Red )
'74 Triumph T-150V Trident
...( It's a Triple )
CrystalPistol is online now
post #8 of 37 (permalink) Old 01-11-2017, 06:40 PM
Certified Slacker
Year: 94
Make: Wing of course!
Model: 1500 SE
Im going with damage to the oil filter, being easy and cheap to fix!
Riding it without cking could be a costly error..... see:buggered!
Aloha Tom is offline
post #9 of 37 (permalink) Old 01-11-2017, 11:30 PM
Yep, I have a buddy who was loading a trike with ramps and the crank case bottomed at the rear of the trailer and knocked a chunk out, instant start of drain. He hit it hard. His insurance co paid local Honda shop to put a engine in it.
...( Vintage Red )
post #10 of 37 (permalink) Old 01-12-2017, 12:25 PM
Roadyrider's Avatar
Year: 1986
Model: Aspencade, 86000 miles
Speaking of finding leaks, they make a dye that can go into your oil or radiator so you can use a black light to spot where its coming from. I just used that method to find a tiny leak in my car radiator. Just thought I would mention it.
I don't know what the key to success is, but the key to failure is trying to please everyone.
-Bill Cosby-
Roadyrider is offline
Crankcase Venting froche Goldwing Technical Forum 18 05-24-2016 07:55 PM
crankcase breather bigdave1 Goldwing Technical Forum 3 10-27-2015 06:34 AM
Gas in Crankcase OldRider2 Goldwing Technical Forum 3 02-11-2009 07:39 AM
GL 1200a Crankcase churchhillmike Goldwing Technical Forum 8 11-10-2007 06:24 PM
Crankcase breather Uturn Goldwing Technical Forum 6 07-16-2007 01:49 PM
