post #1 of 19 (permalink) Old 02-02-2017, 08:34 PM Thread Starter
edromero's Avatar
Year: 1990
Make: gl 1500
Model: gl 1500
Shifter pivot advice
Thanks to recomendation by aloha tom (thank you) i will be looking to add Shifter pivot. Lots of play in my shifter, occasionally jumps out of 4th, and a very tiny amount of leakage (very small)
Im hoping the pivot without seal replacement will suffice, because it souds like seal replacement could end up being a can of worms.
The question is..will the pivot stop the leak, or is it a waste of time to do without the seal a well? Thanks
edromero is offline
post #2 of 19 (permalink) Old 02-02-2017, 08:35 PM Thread Starter
edromero's Avatar
Year: 1990
Make: gl 1500
Model: gl 1500
Also, i didnt see any videos on how to replace seal
edromero is offline
post #3 of 19 (permalink) Old 02-02-2017, 09:00 PM
Pure Texas's Avatar
Make: Goldwing
Really doubt the-shifter assist will stop the leak,damage is already done now,seal replacement isn't rocket science,just need a thin screwdriver to puncture the seal and pop it out.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #4 of 19 (permalink) Old 02-02-2017, 09:42 PM Thread Starter
edromero's Avatar
Year: 1990
Make: gl 1500
Model: gl 1500
Is there any more disassembly required besides what i will already be doing for the shifter? Where can i see/learn the procedure?
edromero is offline
post #5 of 19 (permalink) Old 02-02-2017, 09:44 PM Thread Starter
edromero's Avatar
Year: 1990
Make: gl 1500
Model: gl 1500
edromero is offline
post #6 of 19 (permalink) Old 02-02-2017, 09:49 PM
Pure Texas's Avatar
Make: Goldwing
Here read this.https://www.google.com/url?sa=t&sour...L00_l5Uvh6iz1Q
1969 H1 Kawasaki
1975 1000
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
post #7 of 19 (permalink) Old 02-02-2017, 09:50 PM
http://goldwingdocs.com/forum/viewto...p?f=14&t=19833
Ken Bergen is online now
post #8 of 19 (permalink) Old 02-02-2017, 09:51 PM
Pure Texas's Avatar
Make: Goldwing
Read here,biker251 wrote:
I have a 90 GL1500se and i discoverd today that my shifter seal is leaking also, is it necessary to take the exhaust manifold off on shifter side to change the seal? your help will be greatly appreciated
Jim
That depends on how much room you have to pull the seal and put the new one in. If you can get the shifter off, pop the old seal out with a small screw driver or punch."put it in btween the seal rubber and shaft" and pop a new seal in, " use a socket the same outside diam. as the seal" and an extention and drive the deal in. Be sure to cover the splines and coat the shaft with oil or grease.
1969 H1 Kawasaki
1975 1000
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
post #9 of 19 (permalink) Old 02-02-2017, 09:54 PM
For what it's worth the jumping out of fourth gear is an issue that will bot be cured by installing a shifter brace.
post #10 of 19 (permalink) Old 02-02-2017, 09:56 PM Thread Starter
edromero's Avatar
Year: 1990
Make: gl 1500
Model: gl 1500
I think i could live with it because 1) its only happened 2 or 3 times and 2) im not sure if it didnt happen because i just didnt engage it fully (possibly due to the shifter slop)
edromero is offline
GL1500 Auxiliary Shifter Pivot For sale Peppi-Le-Pew For Sale/Wanted Forum 115 11-17-2016 12:49 PM
Shifter pivot. BugMagnet Goldwing Technical Forum 30 10-08-2016 07:50 AM
Shifter Pivot Power Guy General Motorcycle Discussion Forum 26 12-23-2015 10:24 PM
Shifter Pivot ordered billydva99 Goldwing Technical Forum 12 05-11-2014 12:35 PM
Gl1500 Auxiliary Shifter Pivot installed. Works Boys. Peppi-Le-Pew Goldwing Technical Forum 4 11-16-2013 09:43 PM
