3Likes
post #1 of 15 (permalink) Old 04-14-2017, 11:40 AM Thread Starter
G.Sidecar's Avatar
Year: 1985
Make: Goldwing
Model: LTD
1985 gl1200 ltd car tire?
I see lots of information for a gl1500. Not much information for the gl1200. Has any one put a car tire on theirs? I read that 145/60r15 would work but there seems to be bead and rim issues for full comparability from all manufacturers. I have a side car so it doesn't lean very much. Motorcycle tires I think will get used up quickly. Thanks.
G.Sidecar is offline
post #2 of 15 (permalink) Old 04-14-2017, 04:50 PM
VLADRRR's Avatar
Year: 1996 /1989
Model: 1500
Most people say 15" motorcycle rim is bigger then auto tire so tire damaged at installation. Some install 1500
swing arm final drive and rear wheel on 1200. I use auto tire on GL1500/Friendship 3 and love it.
VLADRRR is offline
post #3 of 15 (permalink) Old 04-14-2017, 04:50 PM
I tried to put 1 on a 1200 rim once and blew up the tire. I have read where others have done it, seems like a 165/70 15 if I remember right.
[SIGPIC]
post #4 of 15 (permalink) Old 04-14-2017, 05:21 PM
Here's a good post written by a member who wanted to put a "car" tire on a GL1200.
Ken Bergen is online now
post #5 of 15 (permalink) Old 04-14-2017, 05:23 PM
VLADRRR's Avatar
Year: 1996 /1989
Model: 1500
I did see 3 15" auto tires on 15" motorcycle rim. 2 told me lot of soap and lot of air will do this job. 1 did machine rim.
VLADRRR is offline
post #6 of 15 (permalink) Old 04-15-2017, 09:16 PM
BrianInPA's Avatar
Model: 1981 GL1200, 1984 GL1200 Standard, & 1987 GL1200 Interstate
I have a 165/80 15 on the 1200 wheel mounted on my 1100. Was it a simple fit? No. I needed to massage the wheel a little so I didn't run into the problem that Dave had.
I've had this wheel/tire on my 84 Standard and now it's on my 81 1200. What did I get by doing this? Just what I wanted. I'm at just shy of 10,000 miles on the tire and it is only now starting to show signs of wear.
I'm currently working on an 87 Interstate, and the last thing I am going to do it before putting a license plate on it, will be to put a car tire on the rear.
AZgl1800 and Screw like this.
Brian
BrianInPA is offline
post #7 of 15 (permalink) Old 04-16-2017, 12:13 AM
Screw's Avatar
Year: 1984
Model: 1200
Well now this has peaked my interest, when the rear tire needs changed I believe I'll go dark side as well.
Screw is offline
post #8 of 15 (permalink) Old 04-16-2017, 06:28 AM
BrianInPA's Avatar
It isn't for the faint of heart for those on the 1200. You either need to machine a little material off of the wheel (approximately 1/8") or use a lot of air and risk blowing the tire.
Brian
post #9 of 15 (permalink) Old 04-16-2017, 12:19 PM
Screw's Avatar
Year: 1984
Model: 1200
I would probably use the increased pressure, But I have a Tire machine. Question, wonder if anyone has put a tube inside this would be a secondary thought really but just wondered? Thoughts?
Screw is offline
post #10 of 15 (permalink) Old 04-18-2017, 01:50 AM Thread Starter
G.Sidecar's Avatar
Year: 1985
Make: Goldwing
Model: LTD
Thanks for the info on the 165/80r15. I saw tire rack as a great chart of all the sizes available to a rim size. My rig runs up right very little lean so cycle tires are going to go to waste.
Okay, can't get car tire on..... Cousin Jack General Motorcycle Discussion Forum 7 06-18-2014 04:04 PM
Car Tire??? woodbutcher Fun Forum 1 09-12-2012 02:43 AM
Car Tire verses motorcycle tire Hogsbreath New Members Introduction Forum 22 05-25-2012 01:50 AM
Bike tire vs car tire Richardrwg General Motorcycle Discussion Forum 37 06-22-2011 12:33 PM
CAR TIRE prosso General Motorcycle Discussion Forum 22 12-27-2009 06:17 AM
