3Likes
  • 1 Post By redwing52
  • 2 Post By Erdeniz Umman
post #1 of 4 (permalink) Old 04-21-2017, 07:53 AM Thread Starter
Model: 1500SE
2000 1500SE - Turn Signal Self-cancel
Last year I had to have may two radiators replaced on my 1500SE. After the work was done and I left the shop my turn signals would not operate properly - wouldn't lock into position (had to manually work them). I was told that it was the switch. This year brought back to shop with new switch. It was installed and guess what, the switch wouldn't lock into position. After some trouble shooting by shop and in contact with Honda Tech it was determined that the Cancel Unit (Turn Signal) in the steering stem had a wire that was not connected. This strikes me as an extremely odd situation that a wire in the steering stem would all of a sudden become loose (disconnect).
My question is when the shop performed the rad replacement last year is there any possibility that they disturbed this connection, eg, move the unit to work on the rads?
If they disturbed the unit then it means that the switch I just replaced was probably okay plus the extra hours they will want to charge to troubleshoot.
All feedback is very much appreciated. Thanks
gwrookie is offline
post #2 of 4 (permalink) Old 04-21-2017, 11:10 AM
Changing radiators is a real pain. I am not sure why the plug was disconnected but they were working in that general vicinity. Hard to believe the signals worked for all those years and quit at the exact time they were working in that area, I suspect there was a cable in the way so they removed it. When they replaced it they did not push the plug home good enough.
Bike...and Dennis likes this.
redwing52 is online now
post #3 of 4 (permalink) Old 04-21-2017, 04:19 PM Thread Starter
Model: 1500SE
redwing52. Thanks for the feedback. That was my suspicion, odd occurrence
gwrookie is offline
post #4 of 4 (permalink) Old 04-21-2017, 09:50 PM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
Probably there was a loose or a poor contact/connection, disconnected plug etc. somewhere on the turn signal circuit, and during the radiator work it has turned out to be a non working turn signal.
Whatever had been the problem, it is obvious that a proper troubleshooting has not been done by the shop.
It could be understood easily that the switch assy was ok, before deciding on the replacement of the switch assy, if the procedure in the service manual had been followed by the shop.
Erdeniz Umman is online now
Turn Signal Cancel Not Working richbloom Goldwing Technical Forum 3 06-03-2014 09:18 AM
Turn signal cancel, GL1100 canuckxxx Goldwing Technical Forum 4 07-02-2013 10:01 AM
Turn signal self cancel on SE-i RobTheHillbilly Goldwing Technical Forum 1 04-10-2011 06:24 PM
Turn signal cancel Xtracho Goldwing Technical Forum 8 02-15-2011 03:36 PM
Turn signal Cancel WinginKy Goldwing Technical Forum 6 10-13-2008 04:06 PM
