post #1 of 8 (permalink) Old 04-21-2017, 01:22 PM Thread Starter
natispotatis's Avatar
Year: 1983
Make: GL1100
Model: Interstate
GL 1100 Xtra Water Pump O-Ring??
I'm replacing the water pump in my 83 GL1100i and I bought the 17 piece gasket set. It comes with 10 O-Rings but I only have use for 9. Can anyone confirm this to calm my fears that I messed something up? Is there an extra ring for another model or pump rebuild? I was led to believe Id use all the o rings.
natispotatis is online now
post #2 of 8 (permalink) Old 04-21-2017, 03:34 PM
cheeprider's Avatar
Model: 1982 GL1100 Interstate trike
I think they use the same gasket for the 1200. it is needed for the 1200 not the 1100. they gasket set you probably have fits from 1975 to 1987. 1000,1100 and the 1200 T29-2286, T29-2287 K&L Supply
http://goldwingdocs.com/forum/viewto...036194d20#p709 Here is link to very good DIY project.
It is better to know where you are going than to get there fast.
former rides
1960 1950 5 horsepower Cushman scooter
1982 1974 750 cc Honda
2005 1991 800 cc Suzuki Intruder
2006 2001 1400cc Susuki Intrude
2009 1982 1100cc Honda Goldwing w/Voyager kit
2013 1982 1100cc honda Goldwing w/Lehman trike
cheeprider is offline
post #3 of 8 (permalink) Old 04-21-2017, 03:37 PM
I can only come up with 9 places for o-rings.
[SIGPIC]
post #4 of 8 (permalink) Old 04-21-2017, 05:51 PM
IT's been a while, but when I changed the water pump in one of my 1985 1200 LTD''s it seems I had a leftover o-ring and it haunted me forever. That was about 40K ago, and still going strong, so.... I still have the o-ring...just in case.
bruce p is offline
post #5 of 8 (permalink) Old 04-21-2017, 08:59 PM
When I buy any "kit" it is not unusual to have extras to make the kit more inclusive.
redwing52 is offline
post #6 of 8 (permalink) Old 04-22-2017, 07:54 AM Thread Starter
Year: 1983
Make: GL1100
Model: Interstate
Thanks. There must just be an extra. After triple checking everything it's been put back together. Putting in the radiator today and we'll see if it leaks. Fingers crossed.
post #7 of 8 (permalink) Old 04-22-2017, 09:00 AM
Model: 1976 LTD (X2) (two apart in VIN)..... 1976 GL1000 Sulfur,... 2008 Pearl White
Decades ago I found that the Honda fiche was missing an O-ring under the front cover. I had to bring the old one in to match it up. After that I made my own list that I would bring to the dealer when I needed to do a water pump. Not sure if they ever corrected the error.
Bill
77Pinto is offline
post #8 of 8 (permalink) Old 04-22-2017, 11:39 AM Thread Starter
Year: 1983
Make: GL1100
Model: Interstate
Bill, that's interesting and kind of a major mistake. I'm glad for the forum to catch these things and provide such detailed help.
Happy to report no leaks so far. Let it warm up and go through two fan cycles. I'm pretty relieved since it's getting warm out and times to ride! I plan to ride a while and then tackle a carb sync.
1100 water pump Wilcoy02 Goldwing Technical Forum 4 12-16-2016 04:47 PM
GL1000 O-ring behind water pump too small? finalcut9 Goldwing Technical Forum 2 10-13-2015 11:18 AM
GL1100 Water pump replacement - extra o-ring Stumper Goldwing Technical Forum 2 08-05-2014 03:10 PM
1100 water pump The Wing Man Goldwing Technical Forum 3 04-26-2014 10:40 PM
O-ring for gl1200 cover by water pump Jalamiller Goldwing Technical Forum 4 11-22-2009 11:50 AM
