4Likes
post #1 of 12 (permalink) Old 05-12-2017, 09:32 AM Thread Starter
Glass's Avatar
Year: 1985 GL 1200A & 1990 GL 1500
Model: Gl1200 Aspencade
GL1500 Cluster Question
So I have read a while back that we as GL1500 Riders cannot completely change out the Cluster because a certain issue. I cannot remember what the issue. The reason I want to Change it out is just that I want to change it out. But In the past I had read but cannot seem to find the answer, when I do a search I keep getting posts in relation to changing the lights in the cluster. I've already done that and Have had no issues. Any factual help would be great.
In my efforts to rebuild my GL1500 I have started and operated the bike without the cluster all together. As well as operated the Reverse mechanism. Everything works in that Nature........Thank You in Advance
Glass is offline
post #2 of 12 (permalink) Old 05-12-2017, 10:26 AM
seafoam guru
Year: 94
Model: 1500 SE
maybe cruise control issue? I know how/where cruise gets its signal changed to camshaft, around 94? was it tach driven before?
You can buy different color face plate and swap that...
Or use a junkyard- complete unit- with one from same year, to eliminate any connector changes or weirdness.
Glass likes this.
Aloha Tom is offline
post #3 of 12 (permalink) Old 05-12-2017, 11:29 AM Thread Starter
Glass's Avatar
So just the loss of Cruise then ? To be honest I've never been able to get my cruise to engage anyways so thats not that big of a deal to me......Great thank you for our input.
Anyone else.
Glass is offline
post #4 of 12 (permalink) Old 05-12-2017, 11:51 AM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
Maybe the answer is the speed sensor which is inside the cluster. It provides signal to the cruise control system, turn signal auto cancel unit, radio auto volume control and rear suspension system through LCD (needs confirmation).
Glass likes this.
Erdeniz Umman is online now
post #5 of 12 (permalink) Old 05-12-2017, 11:57 AM Thread Starter
Glass's Avatar
Ok so i can do without the cruise control, The turn signals and auto cancel to the cruise control as i am using a Signal control Module. I dont have the stock radio on the bike anymore ..........But the rear suspension (Interesting) any Idea as to how it impacts the rear suspension. Or are you saying that if i left the LCD connected it would still work?
I figure that if thats the case that I could remove the LCD and set it up as a separate standalone unit with the temp and fuel gauge.
Thank you for your input I really do like the input on knowledge as this enable me to cover all my bases.
Glass is offline
post #6 of 12 (permalink) Old 05-12-2017, 01:27 PM
That is why I said "needs confirmation". We need someone has tested this before.
post #7 of 12 (permalink) Old 05-12-2017, 03:05 PM
The LCD has nothing to do with the rear suspension except for the display. I guess you could install a pressure gauge or go with seat of the pants.
gipsy42 likes this.
[SIGPIC]
post #8 of 12 (permalink) Old 05-12-2017, 03:11 PM
I think there is something as shown below.
post #9 of 12 (permalink) Old 05-12-2017, 06:00 PM
seafoam guru
Year: 94
Model: 1500 SE
let me be clear- NEVER take what I say as FACT,
It may be Cruise is the issue- I was totally was guessing on that, Might not be any issues or may be 10
Could be something of real concern
Where are the Gurus of rebuilding or customizing??
post #10 of 12 (permalink) Old 05-12-2017, 06:53 PM
I see, perhaps it won't ground the relay if the bike is moving, easy enough to work around.
Erdeniz Umman likes this.
[SIGPIC]
A Question About The Left Hand Handlebar Switch Cluster EnEs63 Goldwing Technical Forum 12 09-25-2016 08:18 PM
instrument cluster GL1500 toolcraft4100 Goldwing Technical Forum 9 02-04-2015 08:09 PM
GL1500 Left Handlebar Cluster doubleu Goldwing Technical Forum 14 03-23-2014 02:15 PM
Tip for those going LED in the GL1500 inst cluster rpeters549 Goldwing Technical Forum 6 10-27-2012 11:20 PM
WTB - GL1500 SE or Aspencade Instrument Cluster lopeha For Sale/Wanted Forum 3 09-11-2012 07:07 AM
