6Likes
post #1 of 27 (permalink) Old 05-12-2017, 03:33 PM Thread Starter
big_sleezy's Avatar
Year: 1983
Model: GL1100 Aspencade
Led Headlight bulb...wow
Well I'm back, different thread, different purpose. Got the old wing running and riding​ great. Now on to some minor improvements.... switching all lights to LED. All 1157's all 168's and the headlight.
General rule of thumb to follow with colored lenses; use the same colored Led bulb.
Today's results: installed Led Headlight bulb. No modifications, plug and play. Went from halogen 55/60w @ 1000 lumen bulb to an LED 24/36w @ 4500 lumen bulb. Preliminary results are positive, will test tonight to verify.
Pictures are as follows first are hi/lo beam with old 60w bulb, then goes into installation, then beam and hi/lo beam pattern with LED bulb.
IMG_20170512_123653-1280x720.jpgIMG_20170512_123646-1280x720.jpgIMG_20170512_123607-1280x720.jpgIMG_20170512_123553-1280x720.jpgIMG_20170512_124725-1280x720.jpgIMG_20170512_124729-1280x720.jpgIMG_20170512_124746-1280x720.jpgIMG_20170512_124755-1280x720.jpgIMG_20170512_124811-1280x720.jpgIMG_20170512_125007-1280x720.jpg
Sent from my ZTE A2017U using Tapatalk
MaxThrust likes this.
big_sleezy is offline
post #2 of 27 (permalink) Old 05-12-2017, 03:35 PM Thread Starter
big_sleezy's Avatar
Year: 1983
Final beam with LED. High then low. IMG_20170512_130010-1280x720.jpgIMG_20170512_123421-1280x720.jpgIMG_20170512_123415-1280x720.jpg
post #3 of 27 (permalink) Old 05-12-2017, 03:52 PM Thread Starter
big_sleezy's Avatar
Year: 1983
Also before the Nay Sayers come pouring in; got the LED bulbs for $28 for 2 bulbs. And the main point of this upgrade is to reduce overall amperage load on the old electrical system. The until corroborated fact that this upgrade will make me more visible is an a big bonus. Uncorroborated until tested, which I'm going to do before I make my sure recommendation.
post #4 of 27 (permalink) Old 05-12-2017, 04:20 PM
CrystalPistol's Avatar
Link to purchase?
https://www.superbrightleds.com/cat/...Type,H4,1,4932:
...( Candy Spectra Red )
'85 GL-1200 Aspencade
...( Vintage Red )
'74 Triumph T-150V Trident
...( It's a Triple )
CrystalPistol is offline
post #5 of 27 (permalink) Old 05-12-2017, 04:28 PM Thread Starter
big_sleezy's Avatar
Year: 1983
Link to purchase?
amazon: https://www.amazon.com/dp/B01KLWDKOO...oding=UTF8&me=
ebay: http://www.ebay.com/itm/NIGHTEYE-LED...FZB-VZ&vxp=mtr
us ebay link: http://www.ebay.com/itm/NIGHTEYE-72W...FZE7tS&vxp=mtr
thats the ebay and amazon link, but i ran into this set on amazon originally here and searched ebay for the same item. I got the original idea from a harley forum i follow, because what ever is good for the sportster might as well be good enough for the wing. 1 bulb for the sporty and the wing in one go.
post #6 of 27 (permalink) Old 05-12-2017, 05:18 PM
corkya's Avatar
Model: 1999 GL1500 Aspencade
Those look great! I hope they have a similar version for the 1500
corkya is online now
post #7 of 27 (permalink) Old 05-12-2017, 05:22 PM
Everybody keep in mind, those don't have a cutoff. To me, having the other drivers in my path be blind, is a bad thing. But if that makes the ride more fun for you...
CrystalPistol likes this.
post #8 of 27 (permalink) Old 05-12-2017, 05:26 PM Thread Starter
big_sleezy's Avatar
Year: 1983
cutoff? are you talking about the cup that halogen bulbs have? If that's what you mean, that's the only thing i wondered about as well. I'm going to adjust the light to point to the right a bit, rather than straight on forward.
post #9 of 27 (permalink) Old 05-12-2017, 09:46 PM
OldNewbie's Avatar
Year: 2003
Make: GL1800
Model: Wing
Pattern focus looks pretty tight to me. I've seen much worse pointed at a wall
OldNewbie is online now
post #10 of 27 (permalink) Old 05-12-2017, 10:29 PM
snowmoer's Avatar
Model: 1988 GL 1500, 2012 GL1800, 1977 GL1000
The question is how are they on the road? There are a lot of posts on LED headlights that they look great, but do not throw the light down the road correctly. This is because the LED is not in the reflective point in the headlight housing. Let us know how it works out.
Dan
AMA Life
2012 GL 1800 Level 3
1988 GL 1500
1977 GL 1000
1988 NX 650
snowmoer is offline
cyclops LED headlight bulb monkey_wrench Goldwing Technical Forum 21 11-21-2014 04:58 PM
80 Watt H4 LED Headlight Bulb (B10-105) ??? Metal_Bob General Motorcycle Discussion Forum 15 09-11-2014 12:57 PM
Gl1200 led bulb upgrade brandi02 Goldwing Technical Forum 1 08-02-2014 09:19 PM
LED bulb replacements fordtek Goldwing Technical Forum 5 06-02-2011 12:59 PM
LED Bulb for sale Munds Goldwing For Sale/Wanted Forum 5 03-18-2007 01:18 PM
