  • 1 Post By DaveO430
post #1 of 2 (permalink) Old 05-14-2017, 06:51 PM Thread Starter
JamesPal's Avatar
Year: 1981
Make: GL1100
Model: Standard - under restoration
1985 Goldwing Interstate - Wiring Grounds
Where are the grounds on the '85 Interstate? I have found the main battery cable (easy) and the green wire connected at the regulator/rectifier. These are identified on the wiring diagram. Are their others? I would like to refresh the Diva's grounding bonds.
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is offline
post #2 of 2 (permalink) Old 05-14-2017, 07:52 PM
Those are the only 2 main frame grounds, there are several in gang connectors all over the bike.
JamesPal likes this.
[SIGPIC]
Grounds, GL1200sei Old Guy Goldwing Technical Forum 8 05-26-2011 12:02 PM
Location of Grounds Aladinbama Goldwing Technical Forum 10 09-02-2010 09:37 PM
Wiring for a GPS on my '84 GoldWing Interstate Stonesword Goldwing Technical Forum 5 04-06-2010 03:14 PM
Fixed CB Antenna Grounds Mohawk Goldwing Technical Forum 9 10-02-2008 08:54 PM
cleaning up grounds martinbikes Goldwing Technical Forum 9 05-05-2007 03:10 PM
