post #1 of 12 (permalink) Old 05-15-2017, 02:09 PM Thread Starter
cj7design's Avatar
Year: 1988
Model: gl1500
New wing with some issues
Just pick up a '88 gl1500 with 140,000 miles on it, it's been sitting for 3 years but still started up. I'm in the process it tarring it down and taking care of some issues I have came across. I am thinking I need to rebuild the carbs, it seams to load up on a couple of cylinders, it clears up when I bring up the RPM's but if I let it ideal it fouls out after a few seconds, only when it's cold. It also has a real bad hesitation when in gear and really bad when starting from a dead stop and also only cold. So while the carbs are off going to go through the vacuum lines and for sure balance them when I'm finished. Have been running Seafoam through it and it's helped but still not running right. One strange thing is the on board air system, the pump works but no air getting to the shock when the P. check/inflate buttons but it will pump up a tube from the line in the saddle bag. If I push the outlet/inflate button the pump does not operate at all. I'm going to start at the switch and fuses and see what I come up with there. Can anyone think of anything else I should check? I have also replaced the timing belt and pulleys, torqued down the exhaust, replaced plugs, oil and filter.
cj7design is offline
post #2 of 12 (permalink) Old 05-15-2017, 02:58 PM
corkya's Avatar
Model: 1999 GL1500 Aspencade
Air and fuel filters?
corkya is online now
post #3 of 12 (permalink) Old 05-15-2017, 04:43 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
There was a service Bulletin for a drivability issue on the 1988 Gold Wing. It was not a recall, the service was only performed when owners returned and complained about the "off idle hesitation issues".
There was also a recall for the Bank Angle Sensor on the 1988 Gold Wing.
Replace the sub filter and cruise filter if they haven't been changed recently.
File Type: pdf GL1500 Service Bulletin (1988 Gold Wing).pdf (2.83 MB, 9 views)
DBohrer is online now
post #4 of 12 (permalink) Old 05-15-2017, 05:23 PM
DBohrer's Avatar
Do you have the extended "air hose" disconnected when trying to supply air to the shock..??
If so then...............
The # 5 air pump relay provides voltage to the outlet switch. (brown/yellow wire) Do you have power here....??
The outlet switch (when free) provides voltage to the increase/decrease switch. (black/yellow wire) Do you have power here....??
The increase switch provides voltage to the air pump motor. (light green/black wire) Do you have power here....??
post #5 of 12 (permalink) Old 05-16-2017, 10:44 AM Thread Starter
cj7design's Avatar
Year: 1988
Model: gl1500
Right know I'm concentrating on the running issues, I will get to the on board air once the machine is running properly.
I will look at the recall when I get the carbs out, this machine original came from California but I'm not going to hold that against it.
Thanks for the all the help
post #6 of 12 (permalink) Old 05-16-2017, 11:19 AM
seafoam guru
Year: 94
Model: 1500 SE
Ca versions have a carbon canister to catch vented gas fumes while parked - that hose on the cap actually goes somewhere!
Fumes are returned to be burned upon engine start.
Does not hurt mpg or do anything weird to the bike.
Certified Slacker is suffering under the delusion of being an expert... We need more Voltage! IGOR- throw the 3rd switch!!
Not the 3rd switch Master!!
Aloha Tom is offline
post #7 of 12 (permalink) Old 05-16-2017, 11:21 AM
seafoam guru
Year: 94
Model: 1500 SE
cj7 Do you have a copy of the owner manual? Once can be provided to you at no charge... by email
How to operate the compressor for different things, and hidden bits about the Wing are in the book
see threads on carbs- there is a mess of vac lines under the carbs, a 90 degree fitting that is suspect,
and beware the rubber heat mat under carb likes to tear on removal.
Have new one on hand- its an important piece
post #8 of 12 (permalink) Old 05-16-2017, 02:20 PM Thread Starter
cj7design's Avatar
Year: 1988
Model: gl1500
Yes I have owners manual and a service/repair/maintenance manual that came with the bike, it even has the original tool kit and tire fill hose in the right bag.
I have been read through them in regards to the operation of the on board air (other things also) and it is not operating the way it tells me it should. The pump will only operate when you press p check and inflate, it will not come on when you push outlet and inflate. I hooked up the hose and attached a tube just to see what it would do and when pushing p check and inflate the pump inflated the tube, so I know the pump produces air at least. Even with the fill hose disconnected there is still no air getting to the shock, I'm assuming that one of the cylanoids it either faulty or bad connection. The P.O. was shocked it did not work so I'm hopping that it's dirty from sitting, like the nutural switch on the reverse lever was and thanks to one of your threads I was able to fix/clean it.
I'm waiting on parts to show up for the leaky cylinder head cover so I'm going to start in on the carbs, will see how that works out.
post #9 of 12 (permalink) Old 05-16-2017, 03:26 PM
DBohrer's Avatar
Did you do the tests in post # 4....??
post #10 of 12 (permalink) Old 05-16-2017, 07:17 PM
seafoam guru
Year: 94
Model: 1500 SE
I pulled out the hose for mine, have to test it for leaks after being coiled for 20+ years and never used.
Better to have an air system and know it works, so YOU will never need it.
Carry a tire plug kit and you are able to help another rider, over 20 actually-lots of plugs in kit.
Makes you the hero on group ride, when you can have a bike back on the road in less than 5 minutes
Not unusual for air line to leak or the Right Rear shock seal to be blown
Must have the aux hose disconnected for shock system to work
All 4 cylinder Wing owners with carb issues should read this redwing52 Goldwing Technical Forum 0 03-15-2015 01:36 PM
1200 gold wing aspencade stereo issues markaleks Goldwing Technical Forum 4 06-11-2012 05:36 PM
75 Wing, almost there - idling issues martinbikes Goldwing Technical Forum 17 09-08-2008 11:06 AM
Wing storage issues doug77 Goldwing Technical Forum 20 01-18-2006 06:23 PM
Wing storage issues Part II doug77 Goldwing Technical Forum 8 11-27-2005 06:24 PM
