2Likes
post #1 of 11 (permalink) Old 05-15-2017, 03:32 PM Thread Starter
Make: Goldwing 1500 SE
Hazard switch
I have a 93 1500 with a defective hazard switch. Can I still get a replacement? If not, can I configure another type of switch? Any ideas would be appreciated. Thanks
flan48 is offline
post #2 of 11 (permalink) Old 05-15-2017, 04:28 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
Hazard Switch
The Hazard switch is not available from Honda (or aftermarket). You would need to purchase the complete left handlebar switch assembly.
What specifically is the issue with your hazard switch? Maybe it could possibly be cleaned or repaired.
redwing52 likes this.
DBohrer is online now
post #3 of 11 (permalink) Old 05-15-2017, 05:27 PM
That left "SE" switch housing is no longer available from Honda.
As DBohrer suggests, maybe all yours needs is a cleaning. That's very common with the Honda switches.
post #4 of 11 (permalink) Old 05-15-2017, 06:28 PM
DBohrer's Avatar
The left switch cluster is the same for 1990 - 1996. As Dennis said, not available.
The left switch cluster is the same for 1997 - 2000. Still available.
There is only one internal part "plate A ornament" and its screw that is different between the 1996 and 1997. Nothing electrical related....!
All the plug connections are the same.
I betcha the 1997 switch cluster will work on the 1996.
Honda frequently makes a minor change then changes part numbers.
Just my thoughts after checking/comparing all the part numbers between the two years.......!
post #5 of 11 (permalink) Old 05-15-2017, 10:32 PM
seafoam guru
Year: 94
Model: 1500 SE
You should try cleaning the switch first, thats a really common problem.
Best to take the cover apart, then access dried up gunk clogging the switch springs- CRC or wd will do, qtips can help dig out loosened crud.
Operate switches numerous times till they work properly, then apply new dielectric grease- any parts store less than $5, replace covers and enjoy
Anyone reading this with a stuck On hazard switch spray wd or crc thru the small opening and operate switch 50 to 1000 times with spraying, until it finally unglues itself.
Often faster and easier on thumb to open the covers and perform some basic maintenance- probably not found in maintenance schedule, unless a small footnote about lube cables and switches as needed
Oh, you mean like... if I ride on Earth?
Certified Slacker is suffering under the delusion of being an expert... We need more Voltage! IGOR- throw the 3rd switch!!
Not the 3rd switch Master!!
Aloha Tom is offline
post #6 of 11 (permalink) Old 05-16-2017, 08:33 AM
joe in calif's Avatar
Model: 1997 SE
It's nice to have everything working properly nut do you ever use the hazard lights? I have owned 7 Gold Wings and have never used the hazard lights. Of course I push on and off all the switches just about every time I ride just to keep them working properly but never had to use the hazards.
IF YOUR BORN ONCE YOU WILL DIE TWICE
IF YOUR BORN TWICE YOU WILL DIE ONCE
A NEW START ON 1/20/2017
joe in calif is offline
post #7 of 11 (permalink) Old 05-16-2017, 09:28 AM
Power Guy's Avatar
Model: Aspencade 1500
I have a 97 GL1500 and have the same issue. I assume its just dirty due to the fact that it feels gummy when i push it in. Like Joe stated, I never use mine either but would like to get it working just incase.
I thought i had read somewhere that you must have either the left or right turn siginal on to make the flashers work. Is that correct? Maybe i was just dreaming.
1977 GS 750
1983 CB 750
1988 GL 1500
1997 GL 1500A current ride
Power Guy is online now
post #8 of 11 (permalink) Old 05-16-2017, 09:42 AM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
No, it is wrong.
Moreover, if you do that you will hear double clicks of the two flashers, and strangely flashing turn signal lights, which may cause some issues at the flasher relays, I think.
However, if you remove the hazard flasher relay, I think you can still have hazard flashing capability by pushing the hazard switch in and turning the left or right signals on, as you mentioned (needs confirmation).
Erdeniz Umman is online now
post #9 of 11 (permalink) Old 05-16-2017, 10:05 AM
DBohrer's Avatar
Power Guy, The Hazard switch has two output power wires.
1. The orange output wire is spliced to the orange output wire from the turn signal switch.
2. The light blue output wire is spliced to the light blue output wire from the turn signal switch.
All the Hazard switch does is apply power to the orange and light blue wires at the same time.
post #10 of 11 (permalink) Old 05-16-2017, 03:30 PM
Power Guy's Avatar
OK. Like i said i have never used the hazard flashers. But would like to get them functional.
Thanks for the feedback
1977 GS 750
1983 CB 750
1988 GL 1500
Hazard switch stuck on stresssolutions Goldwing Technical Forum 10 08-19-2015 02:27 PM
Hazard Switch pictures allen321 Goldwing Technical Forum 3 07-13-2015 05:04 PM
hazard switch applejack Goldwing Technical Forum 7 09-06-2014 04:12 PM
Hazard switch GL1500 jbacrawler Goldwing Technical Forum 1 11-20-2009 04:35 AM
HAZARD SWITCH REALDEAL747 Goldwing Technical Forum 2 05-23-2007 04:03 AM
