4Likes
post #1 of 61 (permalink) Old 05-18-2017, 01:45 PM Thread Starter
Location: Born in Pacific North West now logging in Tucson,AZ
Year: 1984
Make: Goldwing
Model: GL1200A
Question Fuel flowing out of vent
I had done a partial rebuild of carbs
of a GL1200I (new to me) because
fuel was flowing out of vent lines.
But after two weeks the problem
is back again.
When I turn the key on, I can hear
the fuel pump priming. But after
several seceits the fuel starts flowing
out of the air vent 'Tee port'
I am wondering if the floats are
messed-up is that is causing the
problem?
Tucson Sand-Flea is offline
post #2 of 61 (permalink) Old 05-18-2017, 03:44 PM
It has to be the floats or the needle valves. FYI aftermarket valves are pretty much worthless.
Tucson Sand-Flea likes this.
[SIGPIC]
post #3 of 61 (permalink) Old 05-18-2017, 03:50 PM Thread Starter
Year: 1984
Make: Goldwing
Model: GL1200A
Can I still get the floats and needle valves from Moter Honda?
post #4 of 61 (permalink) Old 05-18-2017, 05:09 PM
Yes.
post #5 of 61 (permalink) Old 05-19-2017, 11:40 AM Thread Starter
Year: 1984
Make: Goldwing
Model: GL1200A
[B]When you say: 'needle valves' [[see photo]] are
you referring to - [[see photo]] the,
(a) Jet needle -- (b) Float valve plus Float valve seat
and the (c) Float {yes}B]
Just want to be sure to
order the correct parts --- Thank you
post #6 of 61 (permalink) Old 05-19-2017, 12:02 PM
The "float valve". # 17.
post #7 of 61 (permalink) Old 05-19-2017, 12:25 PM Thread Starter
Year: 1984
Make: Goldwing
Model: GL1200A
#17
HOLDER, NEEDLE JET (NOT AVAILABLE) | Use from Engine SN VD53A B to VD53A C
16165-MG9-014
$30.06
#17 PART OBSOLETE
HOLDER, NEEDLE JET (NOT AVAILABLE) | Use up to Engine SN VD53A A
16166-MG9-004
OK now what? Where Is thenumber on the Engine??
post #8 of 61 (permalink) Old 05-19-2017, 01:39 PM
No, the "float valve", shown on that picture as #17.
#2 on the fiche.
First, make sure the floats still float!
post #9 of 61 (permalink) Old 05-19-2017, 02:30 PM Thread Starter
Year: 1984
Make: Goldwing
Model: GL1200A
#2 on the fiche.
{see photo}
I think this is correct.. "yes"?
Yes! I first will see if floats still
'float'
If float {one or more} dropped in bowls AFTER two weeks;
JUST maybe that is why fuel is running out air vent.
Could maybe when I cleaned carbs --- did not get all junk out
Knowing my lack of luck will dig into mystery and share findings
post #10 of 61 (permalink) Old 05-19-2017, 02:37 PM
azdesertdad's Avatar
Sounds like your floats, aren't. That wing you got from me had the carbs rebuilt about 4-5 years ago by D&D in Tempe. It had the same issue, e.g. peeing fuel out of the vent. they said that the floats are identical with the ones for a 1500, and used those. Just a heads up.
A wing isn\'t an old mans bike, it\'s a wise mans bike. Often that wisdom comes with age.
Four wheels move the body. Two wheels move the soul
azdesertdad is offline
Fuel Flowing Out Of GL1500 Air Vent Control Valve dlkorock Goldwing Technical Forum 11 03-20-2014 04:35 AM
where does the fuel tank on a 1000 vent?? supersonictoys Goldwing Technical Forum 4 08-12-2009 08:39 AM
Fuel running out of vent hose? nightwizard40 Goldwing Technical Forum 2 08-06-2009 11:02 PM
fuel cap vent dakotawings Goldwing Technical Forum 4 07-26-2009 01:18 PM
Fuel Tank Vent Charlie2300764 Goldwing Technical Forum 5 07-07-2006 04:03 AM
