post #1 of 11 (permalink) Old 05-31-2017, 07:55 PM Thread Starter
Mirror Mount
Some may remember my broken windshield garnish issue. (I'll provide a link if I can find it.) Anyway since that repair, I've had a problem with the mirror loosening up. Decided to fiddle with it again and found this. Before it goes any farther, I guess I'll need to take a new tack.
Many have done this kind of repair using ABS glue and shredded ABS plastic. My question is; will that be the best route on such a small area, or should I just get out the JB Weld?
post #2 of 11 (permalink) Old 05-31-2017, 08:21 PM Thread Starter
The earlier thread:
Aluminum Welding
post #3 of 11 (permalink) Old 05-31-2017, 08:54 PM
Pure Texas's Avatar
Make: Goldwing
Can u access that by removing the speaker.
I don't recall how the mirror attaches but if u can access it from the speaker,might u use some kind of washer behind that hole.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #4 of 11 (permalink) Old 06-12-2017, 10:38 PM Thread Starter
Well, the more I touched it to try and clean the area, the more little chunks broke out. I still haven't decided whether to go with ABS glue or JB Weld.
The mount behind that break, that the screw goes in, is like a washer already.
I put some tape on the bolt to keep the hole sized correctly, then put the washer on it to press against the repair while it dries, hopefully keeping that surface flat. It's important that those surfaces don't change, or the mirror won't mount right.
post #5 of 11 (permalink) Old 06-13-2017, 06:18 AM
BrianInPA's Avatar
Model: 1981 GL1200, 1984 GL1200 Standard, & 1987 GL1200 Interstate
I have had a lot of luck with ABS glue and fiberglass mat... the ABS glue is the resin for the fiberglass. When it dries, it is rock solid.
Brian
BrianInPA is offline
post #6 of 11 (permalink) Old 06-13-2017, 11:22 AM
Pure Texas's Avatar
Make: Goldwing
Dennis I think 3m makes a two part cement that works great on stuff like that.
1969 H1 Kawasaki
1975 1000
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
post #7 of 11 (permalink) Old 06-17-2017, 06:07 PM Thread Starter
Well I decided to go with JB Kwik Weld, mostly because I had it hanging on the wall. Also kind of know what to expect from it.
This ain't pretty so those with a weak stomach may want to avert their eyes. I got the mounting area fairly even and near the original profile. Smoothed it out a little with the Dremel.
I don't know if I'll bother to try and clean up the top area. It's pretty ugly but, so am I, so everything evens out.
If this doesn't work...
...I figure out someone to blame.
post #8 of 11 (permalink) Old 06-18-2017, 12:15 PM Thread Starter
It's all back together and ready to ride.
However, it's 10 in the morning and already 100 degrees out there. Maybe I'll wait 'til this evening.
post #9 of 11 (permalink) Old 06-19-2017, 08:43 AM
Year: 2008
Sounds like 4:00 AM would be a better time.
Charlie
flylow is offline
post #10 of 11 (permalink) Old 06-20-2017, 06:49 PM Thread Starter
Even that won't help. Just looked at weather.com and it's 120 out there right now. About 114 in the garage.
I did take the bike out yesterday morning though and the mirror seems to be holding.
fixing broken gl1200 fairing, mirror mount deanbw Goldwing Technical Forum 4 01-17-2015 02:04 PM
FS: Candy Red Rt Mirror Housing/Key Surround/Ram Mount Hey Load!!! For Sale/Wanted Forum 7 08-06-2012 10:29 AM
Fairing Mirror Mount GL1200 escogold Goldwing Technical Forum 6 11-10-2010 05:38 PM
Mirror of GL1500 ,Take off the mirror (glass) from the Mirror Body surapong Goldwing Technical Forum 3 02-10-2009 07:14 AM
84/87 Replacement Mirror lense and Antenna with mount PatinIdaho For Sale/Wanted Forum 0 10-31-2005 05:23 PM
