8Likes
post #1 of 32 (permalink) Old 06-13-2017, 07:37 PM Thread Starter
Model: 2000 SE/2001 Valkyrie/2007 1800/ 2 1970 honda trail bikes
GL1500 reverse
I have a 1999 gl1500 SE when you put the bike in reverse and hit the starter button it will back up for about 5 seconds the it shuts down and you have to disengage the revers lever then engage it again or just keep pushing in the starter button. I have cleaned all the contacts at the switches and the one right under the trunk there is a big red juction block behind the right saddle bag and i pulled that apart and spayed electrical cleaner in there also. any help is well appreciated .Also thisis notmy bike a friend just bought it and it only has 23000 miles on it I amjust trying to help fix it. thanks Ken
bluewinger2000 is offline
post #2 of 32 (permalink) Old 06-13-2017, 08:03 PM
Nobody You Know
88goldwing's Avatar
Model: 2013 GL-1800
Sorry if this is a silly question, but you do know you have continue to hold the starter button down, right?
Ken
2013 GL-1800
1999 CB-750
K 4 D I T
88goldwing is offline
post #3 of 32 (permalink) Old 06-13-2017, 08:56 PM
paradisetexassty's Avatar
I'm sure he knows that. My reverse is doing about the same as his, mine just bumps backwards. You have to continue to het the starter button.I have a '89 gl1500. Would like ro find the problem.
Sent from my SM-G530T using Tapatalk
paradisetexassty is offline
post #4 of 32 (permalink) Old 06-13-2017, 09:11 PM Thread Starter
yes i know you have to keep it held down for it to work so mybe i should have worded it better.
post #5 of 32 (permalink) Old 06-13-2017, 10:22 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
Deleted..................!
DBohrer is offline
post #6 of 32 (permalink) Old 06-13-2017, 10:36 PM Thread Starter
no it will not it has to be in the fully lock position i will check the fuse first thing in the morning i took all the plugs under the trunkapart and spray them with contact cleaner and blew them out with air. thank you for getting back to me
post #7 of 32 (permalink) Old 06-13-2017, 10:37 PM
i just checked mine also, 3/4 way up, neutral light on and no movement
post #8 of 32 (permalink) Old 06-14-2017, 12:30 AM
There are a lot of requirements that must be met for the bike to go in reverse properly. What you are experiencing is the bike starts to back up and the reverse module sees something it does not like. Then it kicks out. The starter relay regulator is a popular one as Dbohrer has mentioned. Has he experienced any other issue you might think are unrelated?
redwing52 is offline
post #9 of 32 (permalink) Old 06-14-2017, 01:01 AM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
Although you mentioned that you move the reverse lever forward and then up again, I want to make sure this point, which may be important.
1.When the bike stops reversing, can it reverse by just pushing the button again without moving the lever forward and up?
2.Will the R light go off when the bike stops reversing?
3.Will the headlight stay on when the lever is up and you push the start button?
Erdeniz Umman is offline
post #10 of 32 (permalink) Old 06-14-2017, 12:25 PM
toolcraft4100's Avatar
Model: '91 Aspencade
I had the same issue with my '91. With some coaching I was able to locate two 5amp fuses kinda bundled together in a little snap-box under the seat near the battery (PO butchered all the electrics in this area on my bike so not sure exactly where yours will be). One of these fuses was blown. I replaced them both. The reverse has worked perfectly ever since.
toolcraft4100
toolcraft4100 is offline
88 gl1500 No Reverse BRW Goldwing Technical Forum 22 03-11-2015 03:31 PM
GL1500 no reverse richard powers Goldwing Technical Forum 14 05-13-2014 02:37 PM
GL1500, no reverse biggrammy Goldwing Technical Forum 6 05-28-2013 08:32 AM
GL1500 reverse use brianl Goldwing Technical Forum 7 05-17-2013 01:15 PM
GL1500, NO REVERSE THE BLADE Goldwing Technical Forum 27 06-20-2012 03:22 AM
