5Likes
post #1 of 30 (permalink) Old 06-13-2017, 08:32 PM Thread Starter
JamesPal's Avatar
Year: 1981
Make: GL1100
Model: Standard - under restoration
Jim's GL1200 - The Diva must have her way - Bleed the clutch
The Diva is being extra bitchy about this. I've got about 12 hours into this so far and I need some help. This is the first motorcycle hydraulic clutch I have owned so I'm not quite sure what I should be looking for. So far I have pulled the master and slave cylinders apart and installed new seals (Tour Max kits). The hard parts were ultrasonically cleaned. Everything was descaled and polished. These are the things I have done to in the order I have done it:
  1. Reverse bleed the clutch. Brake fluid successfully pushed from the slave bleed to the master cylinder. Air remained in the system.
  2. Bled from the master cylinder through bleeder by pumping the clutch and opening and closing the bleeder valve. No fluid flowed.
  3. Bled from the slave bleed valve using a Mighty Mite vacuum bleeder. No fluid would flow and the Mighty Mite would hold 15-20" of vacuum with a slow leak down.
  4. Turned the front wheel all the way to the right. I was able to get fluid to flow and pumped about 200cc of fluid through the slave cylinder. The Mighty Mite would not pull fluid through the slave cylinder bleed valve.
  5. Cracked the master cylinder banjo bolt and bled a burp of air out of that.
  6. Raised the left side of the bike by placing a 5/8" thick piece of plywood under the left leg of the center stand.
  7. Bled another 100 cc of brake fluid through the bleed valve.
The fluid coming through the slave cylinder appears to be fairly clear and no significant air bubbles are coming through. The clutch lever feels mushy and it is difficult to tell if the clutch push rod is moving.
Should I be concerned about the clutch line/hose? The exterior looks like it is in great condition. I have not cleaned the interior. Should it be replaced?
What am I missing? I want this done so I can move on to putting the bike back together. The only thing left after assembly and bleeding is the starter.
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is online now
post #2 of 30 (permalink) Old 06-13-2017, 08:58 PM
When you had the master apart did you clean out the tiny hole under the little metal cover inside the reservoir?
[SIGPIC]
post #3 of 30 (permalink) Old 06-13-2017, 09:07 PM Thread Starter
JamesPal's Avatar
Year: 1981
Make: GL1100
Dave, yes, I ran the largest guitar string that would fit through it. SOP for this maintenance action.
Jim Palmer
Current rides:
\'81 GL1100 Std
\'72 CB450K5
post #4 of 30 (permalink) Old 06-13-2017, 09:21 PM
Pure Texas's Avatar
Make: Goldwing
Just keep bleeding it,sometime it takes a while,does the clutch feel hard after you pump it up? It won't feel like a cable clutch,some of our Semis have hydronic clutches and I almost slam the floor with the pedal but letting off it dosent feel like there's anything there like a mechanical clutch.
Perhaps the clutch is stuck from setting?
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #5 of 30 (permalink) Old 06-14-2017, 05:22 AM
I don't think even the smallest guitar string would fit through it. As I said, it is a tiny hole, I can't even see it without magnification.
[SIGPIC]
post #6 of 30 (permalink) Old 06-14-2017, 11:32 PM Thread Starter
JamesPal's Avatar
Year: 1981
Make: GL1100
Dave,
Guitar strings are the smallest wires that are easily available. A steel E string is about .007 inches in diameter. I keep them around to clean carb jets.
Jim Palmer
Current rides:
\'81 GL1100 Std
\'72 CB450K5
post #7 of 30 (permalink) Old 06-14-2017, 11:41 PM
Dave,
You can cut a chunk out of an old lamp chord and use one of the strands. Or a piece out of a wire brush.
post #8 of 30 (permalink) Old 06-15-2017, 05:31 AM
Dave,
OK, if you used an E string it would fit through the return hole, if you used something larger it was the inlet hole.
[SIGPIC]
post #9 of 30 (permalink) Old 06-15-2017, 07:49 AM
Power Guy's Avatar
Model: Aspencade 1500
Those "Divas" can get a little cranky if you do not take care of them..
1977 GS 750
1983 CB 750
1988 GL 1500
1997 GL 1500A current ride
Power Guy is offline
post #10 of 30 (permalink) Old 06-15-2017, 11:27 AM
If you can reverse bleed , - which is a good method in my opinion , and the fluid raise in the reservoir then your return hole for sure is open .Are you sure you have a quality kit for your master and you have it assembled korrekt ?
JamesPal likes this.
Jim's 1985 GL1200 - The Diva gets new shoes JamesPal Goldwing Technical Forum 2 04-20-2017 11:06 AM
Jim's '85 GL1200 The Diva needs some advice JamesPal Goldwing Technical Forum 12 03-07-2017 09:28 PM
Jim's '85 GL1200I - The Diva has clean Carburators JamesPal Goldwing Technical Forum 5 02-05-2017 03:32 PM
Jim's "85 GL1200I - The Diva Needs New Shoes JamesPal Goldwing Technical Forum 8 12-01-2016 11:45 PM
Jim's GL1200I The Diva is Home! JamesPal General Motorcycle Discussion Forum 21 10-31-2016 10:09 PM
