3Likes
post #1 of 11 (permalink) Old 06-17-2017, 10:29 AM Thread Starter
DBohrer's Avatar
Model: '99 Gold Wing SE
GL1500 Starter Relay A Connections
There has been much ado in this thread regarding connecting the yellow/red and brown/red wires to a GL1500 starter relay A.
Sudden no start
Looking at these two pictures, it is quite obvious which 2 spade terminals are connected to the green fuse holder (supporting power to the ignition switch) and which 2 spade terminals are connected to the starter relay A (to activate the relay).
Knowing where to connect the yellow/red and brown/red wires is easy...peasy...!
trike lady and DenverWinger like this.
DBohrer is offline
post #2 of 11 (permalink) Old 06-17-2017, 12:10 PM
It all may be quite obvious which wires go where, to someone versed in M/C electrics.
I don't understand any of it.
post #3 of 11 (permalink) Old 06-17-2017, 12:25 PM Thread Starter
DBohrer's Avatar
You are out there in AZ close to Stu Oltman. Hasn't he taught you electronics....??
He knows more about Gold Wing's than all the Guru's on this forum........!
DBohrer is offline
post #4 of 11 (permalink) Old 06-17-2017, 12:52 PM
Nope, I do know him. Been to his place a couple times, even. But he's never tried to teach me electronics.
Though we did once argue about carburetor linkage.
post #5 of 11 (permalink) Old 06-17-2017, 01:00 PM Thread Starter
DBohrer's Avatar
I also know Stu..........
DBohrer is offline
post #6 of 11 (permalink) Old 06-17-2017, 05:35 PM
That is assuming it is an OEM relay.
redwing52 likes this.
[SIGPIC]
post #7 of 11 (permalink) Old 06-21-2017, 06:16 PM
corkya's Avatar
Model: 1999 GL1500 Aspencade
When I was having an issue with my 88, I purchased several of these relays and they ranged from $6 to $20 and they all looked exactly the same, and just like the OEM one.
corkya is offline
post #8 of 11 (permalink) Old 06-21-2017, 06:31 PM
gumbyred's Avatar
Model: 1998 S.E.
The O.E.M. solenoid "A" has a color coded dot on it helping you wire it up. The cheap Chinese ones do not.Its how they are made on the INSIDE that makes ALL the difference.
gumbyred
1998 Gold Wing S.E. with 221,106 miles
gumbyred is offline
post #9 of 11 (permalink) Old 06-22-2017, 02:15 PM Thread Starter
DBohrer's Avatar
Have you seen the inside of the OEM relay A.....??
Have you seen the inside of the relay A's from ebay and Amazon.....??
Are you speaking from experience or just making a WAG.....?? Or going on what you have heard from others....??
Just curious.......!!
gumbyred
DBohrer is offline
post #10 of 11 (permalink) Old 06-22-2017, 03:33 PM
gumbyred's Avatar
Model: 1998 S.E.
I have read that the composition of the contact bar has traces of gold in it that makes it hold up better. More copper also.
gumbyred is offline
gl1500 starter relay A gford Goldwing Technical Forum 5 06-23-2016 12:09 PM
Gl1500 Starter Relay chitownwinger Goldwing Technical Forum 1 12-05-2013 03:28 PM
GL1200 Coil Relay, Solder Stator Wire, Starter Relay beechum1 Goldwing Technical Forum 5 12-23-2011 07:19 AM
88 GL1500 starter noise & relay B Duckster Goldwing Technical Forum 12 11-10-2011 02:28 PM
Wana see whats inside that starter relay for GL1500's, PICs onevw Goldwing Technical Forum 7 08-09-2011 06:00 PM
