post #1 of 6 (permalink) Old 06-17-2017, 10:51 AM Thread Starter
DenverWinger's Avatar
Model: GL-1500A Aspencade
Question GL1500 Ignition Trigger Wheels
I moved from Michigan to Denver in 1981, bringing my little Honda CL-350 (my first bike) with me. In Colorado, the altitude affected the little bike severely, it was running super rich, so rich that even with it in neutral with wide-open throttle it wouldn't go past 7000 RPM (on a 10K - I think - red line). No power, just drowning in fuel. Similar situation with my '71 Impala when I first got here.
I took the carburetors apart on both and bought main jets that were 10% smaller in orifice. What a difference that made!
In addition to the carburetor adjustments somebody told me back then it is beneficial to advance ignition timing one degree from spec for every 1000 ft altitude, and I've been applying that 5 degree extra timing advance to every vehicle I've owned since I've been in Denver, with apparent improvement in fuel economy and performance.
My GL1100 is not possible to adjust the timing, but I've been reading about my new-2-me GL1500 and its ignition sys, and have found there's trigger wheels available in 4 or 6 degree from spec advance. I guess these were made primarily to correct issues with the '88 and '89 wings, but might be beneficial for "High Altitude" wings, too.
I'll be changing out the timing belts soon, and that would be the perfect time to put in a new trigger wheel. So this brings two questions:
1) Does anybody in high altitude have any experience/comment about the extra advance in a '90 to '00 GL1500?
2) When I get my nose into the belts, trigger wheel and stuff, how can you tell a factory trigger wheel from an aftermarket wheel if the PO had already put one in?
DenverWinger is offline
post #2 of 6 (permalink) Old 06-17-2017, 12:52 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
Deleted...............!
DBohrer is offline
post #3 of 6 (permalink) Old 06-17-2017, 01:25 PM
CWN
CWN's Avatar
Year: Pro 1500
Model: 41 years winging it
Total waste of $. My 1500 purrs up and over Tioga Pass in Yosemite @ 9,943'.
Calif Wing Nut 1976-2017 Gwoa 1976-Gwrra 353 1978 Life- Cwef 82-Agwa 84-Gwta 87-Cwc 90.
CWN is offline
post #4 of 6 (permalink) Old 06-17-2017, 01:37 PM
Bellboy40's Avatar
Model: GL1500SE Candy Spectra Red
My 1500 has been up both Mt. Evans and Pikes Peak in Colorado, both at over 14,000 feet. It ran perfectly going up both of them. I don't think you will see any improvement by installing the trigger wheel to advance timing.
Larry
-- Albert Einstein
Bellboy40 is offline
post #5 of 6 (permalink) Old 06-17-2017, 09:54 PM
Bluewaterhooker0's Avatar
Make: Goldwing SE
Model: '97 GL 1500SE
You might want to read this article by a guy who seems to be pretty much an expert on carburetors. The GL1500 has CV carbs. The 3rd paragraph spells it out. http://www.motorcycleproject.com/tex..._altitude.html
Thomas Paine December, 1776
Bluewaterhooker0 is online now
post #6 of 6 (permalink) Old 06-17-2017, 11:47 PM Thread Starter
I've already had her down the "Peak-to-Peak" highway, and she ran perfectly fine. But as I stated in first post, other vehicles I've owned once they are "homed" in high altitude benefited from timing advance. The old '71 Impala with 400CID engine was struggling on the mountain drives above Denver (rich) but the main jet change fixed the rich, and the timing advance by 5 extra degrees further helped fuel economy and power when home altitude over 5000 ft.
As I stated, the GW 1500 runs good even driving the high mountain passes, but looking to see if the extra advance had made a difference on a daily basis for somebody that lives in this altitude.....
BTW, the old Chevy would ping a little when visiting family back in Michigan, a little too lean, and a little too advanced.....
Thanks for the responses!
Ignition trigger wheel for a GL1500 Graham B Goldwing Technical Forum 25 09-23-2014 11:50 AM
GL1500 Cams & Trigger Wheels Hey Load!!! Goldwing Technical Forum 2 08-06-2012 07:46 AM
GL1500 Trigger Wheel Andy Cote Goldwing Technical Forum 6 02-13-2011 09:07 AM
trigger wheels twobeerbill Goldwing Technical Forum 2 04-10-2010 12:01 PM
GL1500 Trigger wheel Ogrebro Goldwing Technical Forum 6 05-18-2009 05:42 PM
