post #1 of 8 (permalink) Old 06-17-2017, 08:43 PM Thread Starter
Motox#37's Avatar
New to the site. I own a 99 GW 1500SE.
I am looking for some guidance on how to install the CB/Radio controls. The original control unit broke off. I ordered a new control box that mounts on the top left hand side. I can't seem to find the connectors that are at the end of the wire harness. Any ideas where these connectors connect to? What side and what do I need to remove to find these connectors?
Thank you,
Kevin
Motox#37 is offline
post #2 of 8 (permalink) Old 06-17-2017, 10:42 PM
galaxyhunter's Avatar
Model: 2000 Aspencade
Welcome aboard Kevin. I'll look in my service manual tomorrow. I just changed both of my handle bar controls last weekend and to say it was a PITA is an understatement. Right now, I'm guessing that the connector plugs in the terminal block that is above the left fan, But I'll check tomorrow.
Carl
Honorary Rhino
Astronomy is my main MONEY PIT, But my GW is a close second.
old bikes:
71FX Super Glide
86 Aspencade
galaxyhunter is offline
post #3 of 8 (permalink) Old 06-17-2017, 10:46 PM
trike lady's Avatar
Hello and welcome to the forum.
Retired trike builder.
I.M.B.B.A. Technician II Certification.
trike lady is offline
post #4 of 8 (permalink) Old 06-18-2017, 01:41 AM
John J's Avatar
Year: 1998
Make: Honda Goldwing GL1500SE
Model: GL1500SE
Welcome to the forum. The connector blocks are underneath the left-hand side glove pocket. Just take off the soft cover (the one held with poppers) and you will see 4 cross head screws that hold the plastic pocket in place. Take out the screws and wiggle the pocket out. There are also 4 bullet connectors underneath the rubber handlebar cover that operate the push to talk switch and channel change. Just remove the 2 screws that hold on the left handlebar cover remove it and all will be revealed.
GL1500SE \'98 and Harley Fatboy 2004
Previously:
Triumph Rocket Touring 2010
John J is offline
post #5 of 8 (permalink) Old 06-18-2017, 06:16 AM
Power Guy's Avatar
Model: Aspencade 1500
1977 GS 750
1983 CB 750
1988 GL 1500
1997 GL 1500A current ride
Power Guy is offline
post #6 of 8 (permalink) Old 06-18-2017, 08:53 AM
Kevin, Your four wire ends should have Colored connectors.
1: 4 pin Black
2: 2 pin Black
3: 4 pin Brown
4: 6 pin Black.
If these are you wire ends, Then connect them according to the attachment below (two pages) . These connect to the terminal strip that is above the left fan. Unfortunately, I have not found a way to access the terminal strip w/o removing the left fan. THAT IS A PITA. I could not access the terminal strip going through the left fairing pocket. If someone knows an easy way to the terminal strip, I'm all ears.
Carl
Honorary Rhino
old bikes:
71FX Super Glide
86 Aspencade
post #7 of 8 (permalink) Old 06-18-2017, 03:06 PM
Rocketman911's Avatar
Year: 183 BC
Make: Not telling how much money I make!
Model: Cindy Crawford would be a good one.
Suck it up buttercup! Move out of your mothers basement and get a JOB.
Rocketman911 is offline
post #8 of 8 (permalink) Old 06-18-2017, 06:39 PM Thread Starter
Motox#37's Avatar
Thank you for all of your help! It is greatly appreciated. I'll take a look at it when I get back to the house. Thanks again and hope you are having a great day!
Sincerely,
Kevin S. Davis
Motox#37 is offline
99 1500SE jimsjinx Goldwing Technical Forum 6 10-23-2011 07:57 PM
1500SE TKM Goldwing Technical Forum 3 06-24-2011 03:19 PM
I am new to this site. This is a great site so far. vettster New Members Introduction Forum 23 02-09-2010 05:50 PM
98 gl 1500se xsxlr8r Goldwing Technical Forum 4 07-17-2009 01:27 PM
1500se winger1999se Goldwing Technical Forum 3 06-19-2009 02:12 PM
